actorlife
Ah, ok sorry I misunderstood.
I'll get some pics up of the 3300 with the round pads.
COOL. Rhanks. Got a on the table from China hmmm.
Man i like the looks of the ebay ones better. I appreciate the pics. They look fluffy and comfy can't wait to get them. Listening to the new earphones whoa man the hype they get is deserved. I Think these are in the same league as the ZS3 perhaps even better and more comfy. Guess?
hello, i opened up my shl3300 and planning to rewire the whole thing since the connecting wire on the headband for the right driver broke, but which connector on the driver is for left, right and ground?
I'm planning on wiring both cups into a Y split stereo, the driver has 4 connectors, 2 used originally and 2 unused but solder ready spots, which is which?
Good day slate have you ever made a bluetooth headphone mod that didn't have BT. Just curious. Be something if the 3300 could have that function. I mean if they can put them on earphones should not be a Problem. New project?
OK I got the pads. The soundstage is way better for Sure. I got small ears SO they rest inside cushion. They are darn comfy. I feel that the bass lacks though. I get more bass with the stock earpads. The soundstage and separation is fantastic with the ebay pads though.
Yeah, the bass reduces slightly due to the increased volume vs the larger pads (just like the difference in bass when using small bore vs wide bore tips on in-ears).
Do the open grilled mod. You'll have all the bass you'll ever want!
I may do that i don't have the tools to do it Right Now. For the moment I'll just turn up the bass. How about using a drill and make four to seven small to medium holes?
Yeah, that would work. Just open them up so you can see where you're drilling (to make sure you avoid any wires & the spring loaded bar going across the center of the cup).
So yeah, if you do it that way, all you'll need is a drill & some type of glue to put the cups back together.
