[REVIEW] Philips SHE9850
- Thread starter ClieOS
Sinocelt
- Nov 10, 2005
Man, that was fast! Thank ye kindly! While we're at it, could you provide me with the winning numbers for the next national lottery draw (in Taiwan)? I'm sure killkli would be interested, too.
Back to the SHE9850: it is indeed a good-looking IEM, but it seems to stick out quite a bit, so I wonder how well it can stay put through a work-out that involves a fair deal of head-twisting (such as, let's say, spinning hook kicks).
Wong
- Mar 22, 2009
Nice review ClieOS.
The SHE9850 is indeed a very good-looking IEM, but it is way overpriced here in Singapore. Jeez, $110 for these. (yes, that is in US Dollars).
Close to $125 actually
Guess where I got mine?
With the foam tip, you can run with out any problem. You can wear them up-side-down when you are working out so they will stay in more securely.
Wong
- Mar 22, 2009
Sim Lim Square?
Originally Posted by ClieOS /img/forum/go_quote.gif Close to $125 actually |
Sim Lim Square?
- Jun 11, 2004
I got mine from Audio House (Singapore).
Absolutely loved it.
It sounds laid back to me, just what i need on some days after lots of high energy sounds from my Image x10 and SE530.
It even sounds surprisingly good (read: relaxing) on certain dance tracks like Moloko's Sing It Back.
It's a huge upgrade from stock buds, and sure pleaser to newbies, and a satisfying collection to oldies too haha.
And it looks oh-so-beautiful maybe that's why i'm probably biased hurhur
Sinocelt
- Nov 10, 2005
Due to over-sensitive hearing, I wear foam earplugs everyday. They must be replaced fairly often, for hygienic reasons. To buy Comply tips even only half as often as I buy regular foam earplugs would quickly cost me more than the IEM itself.
Originally Posted by ClieOS /img/forum/go_quote.gif Close to $125 actually With the foam tip, you can run with out any problem. You can wear them up-side-down when you are working out so they will stay in more securely. |
Harvey Norman actually. I know, not a good place to shop for headphone
That's why I use Shure olive (black foam sleeve) on mine. It can be washed, cleaned and reused. The first pair of olive I bought over a years ago still perfectly fine on my TF10. In comparison, Comply only last about a month for me.
Originally Posted by Sinocelt /img/forum/go_quote.gif Due to over-sensitive hearing, I wear foam earplugs everyday. They must be replaced fairly often, for hygienic reasons. To buy Comply tips even only half as often as I buy regular foam earplugs would quickly cost me more than the IEM itself. |
kRze
- Feb 24, 2009
Nice review!
Madpierrot
- Mar 12, 2009
I bought a pair of these about 2 weeks ago with similar impressions. I noticed that the "Philips" name written across the silicon of the earbuds just below the L/R labels has started to fade/scratch off. In fact i've noticed this happen to just about every pair of earbuds that i've had - is this normal?
Sinocelt
- Nov 10, 2005
Do the Shure olives fit the SHE9850 easily? Or do they need to be forced in? Or even modded?
As a sidenote, I have the SHS8000 and I like them a lot: they sound good, fit well and comfortably, and stay in place. They look better than any other IEM I owe and most I've seen, and seem more sturdy. They're an open design, though, so they don't isolate much: they aren't the best choice for commuting, etc.
The writing on my Sensa Clip quickly did the same. It depends on the product, I guess, but letters painted on plastic can't be expected to last forever.
Originally Posted by ClieOS /img/forum/go_quote.gif That's why I use Shure olive (black foam sleeve) on mine. It can be washed, cleaned and reused. The first pair of olive I bought over a years ago still perfectly fine on my TF10. In comparison, Comply only last about a month for me. |
Originally Posted by Madpierrot /img/forum/go_quote.gif I bought a pair of these about 2 weeks ago with similar impressions. I noticed that the "Philips" name written across the silicon of the earbuds just below the L/R labels has started to fade/scratch off. In fact i've noticed this happen to just about every pair of earbuds that i've had - is this normal? |
Shure olive will fit SHE9850 just fine. It will require a little pushing on the last bit since the nozzle has a small bump at the end, but nothing major. No mod what-so-ever.
Wong
- Mar 22, 2009
Definitely not.
Courts isn't the best place either. However they were selling for SGD 169.99 which I think was less than what you got it for at harvey norman.
Originally Posted by ClieOS /img/forum/go_quote.gif Harvey Norman actually. I know, not a good place to shop for headphone |
Definitely not.
Sinocelt
- Nov 10, 2005
ClieOS, of all the IEMs you've tried, which had the best isolation? Which one was the most comfortable?
Too late, damage done
Best Isolation: Etymotic (any)
Most Comfortable: Westone UM2 (almost as good as Ety on isolation too)
Originally Posted by Wong /img/forum/go_quote.gif Courts isn't the best place either. However they were selling for SGD 169.99 which I think was less than what you got it for at harvey norman. |
Originally Posted by Sinocelt /img/forum/go_quote.gif ClieOS, of all the IEMs you've tried, which had the best isolation? Which one was the most comfortable? |
