I had the HD600's but they hurt my jaw so I sold them off. My DT990's seem to pair well with the LD and my current installed tubes.
I really enjoy this amp and have had it forever. I believe my gain is set to 5...I know it's not 10.
Haha we must have very different heads. The 6X0s disappear on my head after a bit. And I had the Beyer Tygr for gaming (which I believe has a similar fit to 990s) and found that uncomfortable after a while. So long as we find what works for us!
The only other Beyer headphones that I have read about being great are the T1.2's, but they are pretty pricey. Looking into tube amps over the years, the same suspects always pop up:
1) HD650/6XX
2) HD600
3) ATH R70X
4) Beyer T1.2's
At least in the affordable realm, although the T1.2's are pretty pricey even used (I am in Canada).
Just wondering if anybody had come across a headphone that surprised them when hooked up to their LD amp and became a favourite.
I am dying to get mine and see what version it is (how do I do that?), then choose a tube type (E95?) and then set the gain at 4 or 5.
This is my second time buying the 6XX's and I bought the HD600's twice in the last eighteen months. I am not a fan of either headphone on SS amps, but they really do sing with tube amps. At least the HD600's do. This will be first try with the HD6XX's and a tube amp.
Now I didn't expect that! I bought a low impedance tube amp to feed my Grado's as I assumed an OTL amp would only really fly with higher impedance headphones.
What gain do you have it on?
Well, I finally got my amp and tubes. I turned it over and I see the gain switches. How do I tell what version the amp is? And how do I check for which tube type it is set to run? E91/E95/etc.
Thanks for the link. Mine did come with instructions, but it is different than yours and now I see why. Mine are for the Little Dot MKII! In which case the E95 setting is NO jumpers.
So, it looks like my jumpers are fine and I have set the gain to high.
I like the sound. Tried the Yugoslavia tubes and there was some awful noises, particularly in the left side.
I reversed the power tubes and replaced the drivers with the 5654's. Dead quiet, but kind of small sounding, I thought. Without giving them any real time, I switched over to the Voshkods. Very nice sound.
Doesn't have a lot of power though. I am getting a little volume bump from the Loki in the chain, but it is pushing 1:00 for modern music with 3:00 for older music. I am using Beyer DT880 (600 Ohms). They are sucking out every bit of power. Nice sound though.
Turned off the Loki and the amp volume needs to be at 2:00.
I don't stream. Music made in the last 30 years is a lot louder than it used to be and it doesn't matter about file type.
Maybe streaming evens all that out. My DAP can do that, but I don't like what it does to the music.
