regal
- May 27, 2006
it may depend on your soundcard. Some you have to manually set to the bit/sample rate you want, most just can't do it in ASIO or KS.
Have you tried KS and ASIO? I've had similar issues in the past with foobar, just switch around different bit-perfect software, and if that doesn't work, tell us what version of foobar you're using, 1.0 right?
