sarora
That's dramatic. Maybe you should share your findings with John Atkinson from Stereophile, who was unable to measure any differences with/without the Jitterbug.
I checked a bit into it - looks like the JitterBug isn't directly compatible with the C5D. With my MacBook which normally recognizes it natively, the JitterBug causes the audio input to (sometimes) depending on - I suspect power usage - to appear as "Bravo-X Audio" which is the controller inside the DAC/AMP. Most of the time, however, it shows up as IO GENERIC BUS and that's what that output FFT (second graph, first is normal) was, hence the odd pattern and unrecognizable waveform. AudioQuest says this is a known issue on "a few DAC's" -- however, I tried two controller boards that have built in DAC's (my DDJ-SX2 and a Traktor S4 MK2) -- both were not recognized with the JitterBug. I guess anything that requires power at the USB hub gets kicked by the filters in this device. Already don't like the vibe with it because it seems so artificial for a passive device.
That second FFT graph (I listened to the output just to see what it'd sound like and it sounded like gargled microphonics) is the result of the IO GENERIC BUS output. They recommend using a powered hub in this case, which I have but have not tried. Nevertheless, from what I can find online, it just seems to be a common-mode choke and maybe a low pass filter; it's sort of suspect with their usage recommendations IMO. I have yet to see any improvement, mainly because my DAC's don't work out of the box with this. But I will plug in my powered hub and see how it goes and re-run the FFT's from the scope.
