Arsis
- Apr 2, 2013
Joining the ranks! im50 on the way!
After much testing I'm starting to think the im50 maybe a better option for walking and commuting. When I'm out and about I find the bass of my im70s gets a bit lost in the background noise, the extra bass of the im50 should fix this issue.
I've tried IM02 and Re400. Asuming that Re400 and Re600 have some similarities. I can say that none of those have that Grado sound signatures. Instead I can recommend you getting IM50/70 which sounds more Grado-ish.
If you want an IEM more which sounds more like a Grado you should better search for Ortofon eQ-5.
One thing I found recently: The Ortofon and IM02 frequency response graphs look very similar.
Take a peek here:
IM02: http://en.goldenears.net/49122
eQ-5: http://en.goldenears.net/13706
If you look at the graphs carefully, you will see eQ-5 has more of lower treble presence than IM02 and that little peaks on the graphs change the sound a lot. Needless to say they used Comply tips on eQ-5 which is not so good to pair with IMO. I don't trust that measurements, sorry.
They are both different IEMs.
Ah, I see.
How much would eartips change the sound? I have a bit of a preference for foam, so I'll probably be using the Complys more often.
Question: How does Amazon's return policy on stuff like this work? I'm considering just buying both and returning the lesser pair.
Yes, you can buy both and return the one you liked least.
will be posting my long overdue impressions of the im01 soon. right now i can say that the left channel sounds louder than the right and is downright distracting. anyone have this issue with any of the other models in this line?
