It really depends on your music tastes and if you will be ok with a mid-forward sound.
i listen mainly edm like dubstep trap and Progessive vocal. i want something with the best cleanest vocal possible.
IM-03 and 04 are both good with vocal. More transparency on 03 but more Lushy and smooth on 04. Also 04 is more punchy and bassy, where as 03 is less bassy but more overall transparency.
might get the im02. i have really bad impression on audio technica i had some anc29 and ckb50 and there not so good. Might be because there cheap models
would this be upgrade over the dunu 1000
That's like judging an automaker based on some 20 year old broken down car you drove once.
There way to expensive trying to say around the 100-$160 range
Either trying to get the eph 100 IM70 or the im02.
Why no CKR9? It's the best out of those overall.
Are they really better then im02 in the same price range?
I think they are. The CKR9 has better subbass, bass response, soundstage, and depth. They're on par in terms of detail, resolution, and transparency. I really didn't find it much of a contest in terms of the overall package.
^ also less picky than IM02
Will there be any night and day difference between the ckr9 and the dn 1000.
For the eph and im70 which one would be better
The CKR9 and DN1000 are different sonically but fit in a similar range. CKR9 has better vocals to me and more forward mids, where the DN1000 has more bass with a v shape and a sharper treble (as is true of most hybrids). Both on par overall but do things differently.
