Stevesebastianb
- Aug 31, 2008
Yes, it really is quite silly that the amp can't be found over here even since it is made in China?
Originally Posted by Stevesebastianb /img/forum/go_quote.gif Musical Paradise quoted $69 for surface shipping and did not quote the airmail cost - my guess is that it probably cost more then the amplifier, LOL. |
Originally Posted by pkrdlr007 /img/forum/go_quote.gif Skylab,does this amp have a self biasing feature for the tubes?. |
Originally Posted by Hz_joe /img/forum/go_quote.gif US$69 is good enough ship from Hong Kong to USA/CANADA by EMS. I'm design some new Headphone amp use difference tubes now. It will combine Jade & MG-Head OTL topology to become a New structure. 1. Plate Load by a Multi-tap autoformer, Tap will connect to a output coupling capacitor. 2. When switch turn to tap of Autoformer - It is tranformer coupling. It can lower the output impedance to much lower & drive Low impedance cans better. 3. When switch at plate position. It become a Choke loading OTL output form. Will have wider bandwidth, more high resolution. It is more suitable for high impedance Cans. 4. It still can output from Cathode just like Jade. I'm choiceing output tubes for these new series of HP amps now. I'm consider 6BQ5 , 6V6 , 2A3, EL34. (Why EL34 still be consider due to it has low plate resistance when connect in triode mode, It around 1K Ohm only.). First model will be 2A3. May be design it in Module, Users can change tube module to use difference tubes. |
Originally Posted by Stevesebastianb /img/forum/go_quote.gif Yes, it really is quite silly that the amp can't be found over here even since it is made in China? |
Originally Posted by Hz_joe /img/forum/go_quote.gif May be I can help you to buy & send it to you. No Service charge. |
Originally Posted by Stevesebastianb /img/forum/go_quote.gif That would certainly be interesting! I have interest in 2A3, 6V6 and 300B tubes being used for headphone amp. The 6L6 is also another tube. Joe do keep us informed. BTW the Jade is begining to open up very nicely and I am enjoying it very much. |
Originally Posted by Hz_joe /img/forum/go_quote.gif May be you also interesting on : ¹¦·Å¡¢¾ùºâÆ÷-Ö麣ÊÐä¿°ÄÃÀÐǵç×Ó³§ |
Originally Posted by Skylab /img/forum/go_quote.gif Wow! Looks really nice! I wonder if that is imported into the US? |
