Any bi-flanges that fits UE should fit NE-7M, but I don't have any particular brand to recommend since everyone is more or less the same (beside UE, which tend to be stiffer)
[REVIEW] Multiple IEM Shootout v.2
- Thread starter ClieOS
- Oct 31, 2008
if as clieos says UE fit on then try the tips at the end of signature
Originally Posted by maraca2020 /img/forum/go_quote.gif thanks. but I was really looking into bi-flange. Any good bi-flange that fit? |
Bilavideo
Caution: Incomplete trades.
- Feb 29, 2008
Nice set of reviews! You b@st@rd, you beat me to the punch and with more phones! (Now, I'll have to destroy you. MUHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!)
maraca2020
- Jun 7, 2009
sorry, but what is UE?
EDIT: Also, I was looking at comply t-400's and the Sony EPEX10A/BLK Hybrid Replacement Earbuds. Those are the sony hybrids everyone talks about, correct? Which one of these would be a better choice? And are the hybrids silicone or foam? thanks again.
Originally Posted by ClieOS /img/forum/go_quote.gif Any bi-flanges that fits UE should fit NE-7M, but I don't have any particular brand to recommend since everyone is more or less the same (beside UE, which tend to be stiffer) |
I believe UE stands for "Ultimate Ears".
The Sony hybrids are silicone. I just ordered a set from Amazon. The bad thing with the hybrids is that you have to spend about $12 to get one set of tips. To me though its worth it. I have tried all kinds (including Comply) and the Sony's work best for me. YMMV.
Originally Posted by maraca2020 /img/forum/go_quote.gif sorry, but what is UE? EDIT: Also, I was looking at comply t-400's and the Sony EPEX10A/BLK Hybrid Replacement Earbuds. Those are the sony hybrids everyone talks about, correct? Which one of these would be a better choice? And are the hybrids silicone or foam? thanks again. |
Bilavideo
- Feb 29, 2008
UE = Ultimate Ears (maker of the $1100 UE 11 Pro)
maraca2020
- Jun 7, 2009
great. is the Sony EPEX10A/BLK Hybrid Replacement Earbuds (Black) the exact one you're talking about? I think I'll go with those. Also does it fit on the ne-7m? and can you get it at best buy? Thanks
For me, Comply provides great comfort but it is pricey since you have to keep changing it, so I usually avoid using it. Those Sony Hybrid will fit on NE-7M. I think they are available at SonyStyle and Amazon, but I am not sure whether BestBuy has them or not.
Early on, I looked at a couple of Best Buys for these and they didn't have them. I ended up getting them from Amazon.
Originally Posted by ClieOS /img/forum/go_quote.gif For me, Comply provides great comfort but it is pricey since you have to keep changing it, so I usually avoid using it. Those Sony Hybrid will fit on NE-7M. I think they are available at SonyStyle and Amazon, but I am not sure whether BestBuy has them or not. |
clasam
- Jan 3, 2009
Absolutely Brilliant! Well done.
Any chance you could do a comparo with Atrios and Sleeks?
On a more unrealistic note, what about custom iem comparisons, especially the $350-$500 range.
Like: JH5 Pro, UE4 Pro, Alien Ears/Hearyourself.com C3, Fidelity Triples...*takes a breath*
or Unique Melody/Null audio universal-to-custom mods (IEM Remolding + Modification Service (SF5Pro, TF10Pro, UM2), uniquemelody) The Unique Melody modding page isn't translated into English yet, however.
No problem if you can't, since I've already gotten so much for your reviews!
Thanks,
Jon
Thanks,
Jon
SA6 and Atrio have been previously compared, check out the old review/comparison thread in my signature. I don't do custom - not that I don't like to, but they doesn't justify the cost from a collector standpoint. I'll stick to universal for now.
clasam
- Jan 3, 2009
Gotcha, thanks
Originally Posted by ClieOS /img/forum/go_quote.gif SA6 and Atrio have been previously compared, check out the old review/comparison thread in my signature. I don't do custom - not that I don't like to, but they doesn't justify the cost from a collector standpoint. I'll stick to universal for now. |
Gotcha, thanks
clasam
- Jan 3, 2009
ClieOs, any plans to review the ie8 or ie7?
Sennheiser are still expensive locally. For (around) the same price, I am more interested in UM3X. Then again, I really don't have any plan for top-end universal at the moment.
yeah, top-end product already have many reviews, better searching for unfamous products like brainwavz
