Ok .... I have been listening to the amp on and off since around 10:00 am this morning. I am using a Sacdmods 555es > Enigma Audio Oenomel IC > Beta Novo > Alessandro MS2i with the Earl pad mod (19545 pads cut so the driver and housing are completely exposed) .... this pad mod reduces sibilance and brightness vs all the other Grado pad types I have used.
Uh oh controversy JP.
The last description of this amp I would give is congested.
From the very first listen the Novo is very clean and clear sounding IMO. The amp is fast too. But, transient leading edges do seem a little to emphasized sometimes .... and that excess adds some etch to consonants. The soundstaging is a little strange. With my Alessandro MS2, if vocals are present, the amp gives a solid center image with good depth. Play instrumentals and the sound seems to come mostly hard right or hard left with not much middle.
The Novo generally sounded good out of the box with good dynamics, a nice tight bass, good instrument seperation and good extension at the frequency extremes . But, the amp does fatigue me some after 20-30 minutes. I kept turning the volume down but volume didnt appear to be the issue. Maybe the power supply is adding some artifacts? I dont hear anything amiss I can describe as the sound is good .... but my ears dont like something. I used the ground post the next listening session and that made no difference .
I dont have any SS amps besides the most excellent $125 Mini3 portable. The big difference, while I dont hear any major noticeable differences with the Mini3s vs Novos actual sound .... is I can listen to the Mini3 far, far longer without any ear fatigue. Right now, I have a $100 used Millet Starving Student hybrid hooked up with the same Source/ IC / Headphone for comparison .... so far I like the Millet much better. The Millet sounds more natural/ coherent, definitely less fatiguing, more dimensional and I dont get that etch I hear with the Novo. The Novo has tighter bass than the Millet but the Millet is weightier and avoids that ultra clean sound that wears on me with most SS.
This is only the first day and at various points I will be trying Senns, a Buffalo dac, maybe my Opus /zap dac and a different Enigma Audio copper IC that might help with the etch and/ or fatigue.
