Feilong4
A bit late but how do these compare to the Etymotic HF5 if you have tried them? Thanks!
I don't know if this is a right place to ask this question. But still.
I have owned a Hifiman RE262 since 2 years ($150). And it was working fine for an year and half but then it developed an issue in one of its head. The sound from the left head or ear piece sometimes vanishes. I'm assuming a wiring connection gone lose internally.
Now I had contacted the Hifiman customer care support and they say that the RE262 have been discontinued & also the warranty is available for an year. And they are offering me a replacement of RE400 for $50.
All of this is fine.
But what I can't decide on is :
1.) The Sound Quality generated by the RE400. Will it be at par with RE262. I used to like the sound of RE262. Not love it but still adore it. I loved its wide sound stage the decent distinction between the instruments.
I did not like its laid back bass. The bass was sometimes an issue in certain kinda music but in rest I felt the bass was decently natural if not laid back. And yes that it did not have any issue in high note e.g. Female voice hitting high notes, or guitar high notes.
Produced pretty nice sound at higher volumes with any cracking of the sound.
2.) Maybe I'm a bit too naive but I feel that paying $50 for replacement to an RE400 doesn't seem wise in a monetary sense.
As it just seems only a $50 off.
Please give advices regarding this. Is there any other option.
What about cable durability I've seen many complains at amazon reviews stating the RE400 does not last long due to a seemingly frail cable. Is there any revision of the cable with a better quality kevlar reinforced version?
Does anyone know if HFM will replace them under warranty for the cable protectors coming loose? Now after 8 mo., BOTH of mine have pulled out. You have to spin them around to figure out L and R, pretty annoying.
Email them, they may replace them under warranty![]()
I've been reading pages and pages and don't see anything, but has anybody use these with a e11k? If so, how do you feel about the sound quality? Do they sound much better amped?
Not sure if the e11k, but I thought they paired well with a FiiO E11. It made them a bit fuller and added just the right amount of low end boost for certain genres.
