rawrster
- Oct 22, 2008
http://www.fischeraudio.com/place.php
hey that sounds pretty ideal!
i just got probably the best seal i've had on these yet and they're GLOWING on every note, then 2 min down the road one starts to sneak out : [
it's those little turns you to to look to the side that tug them out gently. do you have any links i might want to follow for some tips research or suggestions? i'm not sure about what foam tips to look for in the first place-- granted i'll be doing my own research (that's how i came across these gems in the first place!) but any advice would be very welcomed
