I have had the UM2 for years and love them. They are rich, slightly on the warm side and full-bodied. They are a tiny bit rolled-off in the upper range, but that can work with certain music or moods. Bass is fairly big, but not like the SM3... which is HUGE.
The DBA-02 is different in that the bass is not as extended or pronounced, and the upper mids and highs are very well presented. They might be considered bright. They have better ergonomics for me than the UM2 (but that's no slight against the UM2), in that I can insert and angle them as deeply as I want... and with these, deep is very good.
The DBA-02 are my daily-wear IEM's. They are clean, crisp and brilliant. For classical they are extremely good as the highs are so very important to me. The mids and lower-mids on the DBA are excellent and can really give instruments a solid body feel (not like the UM2, but close).
Hope that helps...
shane
