Exesteils
- Jul 2, 2013
Gawd those ASG-2s look pretty as *****
If you're in the States, drop an email to Dale of Aurisonics. He'll point you to the local authorised dealers.
Musica Acoustics is based in Japan.
Unfortunately, I'm not in the States. I will have to deal with importing it or get from 3rd party online retailers which will most likely push up the cost for me.
I see.
Anyway, just drop them an email and I'm sure he'll point you to the right direction, in case your country already have appointed authorised dealer
But the SD3 isn't on the same technical level at all, even accounting for signature preferences.
The IE800 isn't my fave
So I was following this thread and found the ASG-2 very intriguing. My current iem is the Sony EX-1000 which is single 16mm dynamic driver and I love it for offering excellent bass, huge sound stage and nice clarity using just 1 driver. I have been searching around for my next upgrade and it seems like the ASG-2's description of a 15mm dynamic driver with a pair of specialized BA as its tweeter is the perfect upgrade for my EX-1000. Is there anyone out there who has heard both EX-1000 and ASG-2's sound signatures and can kindly give me a brief comparison? If it is similar to EX-1000, I can then go ahead and put my money on ASG-2. Also where is the best place to buy ASG-2? I don't see it available on Aurisonics website (there are only ASG-1/s and AS-2). The only other place I can find ASG-2 is from Musica Acoustics. Is it a reliable place to buy from?
Go for the upgrade, I demoed the ex-1000 right after I got my asg-2
Compared with the ie8, 4.ai, tsar,SE535, tf10 etc and the ASG-2 is easily a tier or, two higher than most of them...
