project86
- Feb 21, 2007
Any idea how this would mate as a DAC to my EF2? Would it render the EF2 unecessary?
I've only heard the EF5, which is supposedly pretty similar to the EF2 as far as amps go. The EF5 is better than the amp section in the Audinst, and I'd bet the EF2 is as well. But we are comparing a somewhat euphonic tube sound to a fairly typical clean sounding solid state sound, so it is apples and oranges. If you could afford it, I would use both; Audinst is surely the better USB DAC, and then you could use either one for amping depending on the music, the headphones, or your mood.
I sometimes pair the Audinst with a Fournier HTA-1 which is a hybrid tube amp that sounds pretty similar to the EF5. It makes for an excellent combo, so the EF2 should be similarly good.
