earthling
- Nov 27, 2002
....Other than the size I like the design, it looks very good in person. It's nice to have a remote control too.
There is a relay that clicks in around 81 on the volume knob (switching between 81 and 82) that allows the anedio to continue to operating in its highest quality mode. Just an FYI so that if you are using the remote to change volume you will hear the effect of the relay switching in, and at lower volume levels you will hear it externally to the headphones as well. If you set your Lyr so that you are operting the anedio above or below that setting it will be seamless.
