Thanks for the fast update
@tjstyle . That's the kind of support I wish more manufacturers had. I know the P1 isn't perfect but for such a limited release your dedication is much appreciated.
Speaking of the P1, man I can't stop listening to this thing. It sounds amazing! Haven't even touched my desktop in several days despite (just a week ago) finally getting the balanced tube amp I'd long been waiting for. The amp isn't even close to being burned-in but I haven't turned it on since I got the P1 running. The P1's sound is so impressive I'd rather just use it than deal with multiple pieces of hard wired gear.
To that end (plus I have a bit of time on my hands) I've already done the update to firmware 1.09 that TJ just posted and it definitely helps with compatibility. I copied over a handful of additional HD albums that I hadn't gotten to yet with the P1 and all files play successfully. However I think I've found a possible root of the problem:
Although native Hi-Res FLACs now play easily, I'm hearing a lot of clipping and often the same noises as before. It's mainly happening with my 24/48 and 24/96 files so the P1 may have issues with Hi-Res 48kHz samples (or any multiple of 48/96/192).
To confirm, I copied over the lone 24/192 WAV file in my collection. Sure enough, it barely played and was so choppy you couldn't tell it was supposed to be music. I then converted all 48kHz based stuff on my memory card to 16-bits and they all play fine now. Don't like giving up 8-bits of data but at least it works.
EDIT: Still have a lone album that's getting skipped despite converting it to 16/96 WAV.
