I agree totally. The RE0 might sound close to its best with a hotter source (like an iPhone 3G), or with a "starter" amp like a Fiio E5, but the RE1 definitely needs a real amp to approach its potential.
Also in agreement; if you are using the T3, the RE1 would be my choice, but the RE0 could probably be used without the T3 with the 3G iPhone. If you can afford it, get them both and sell one off or return it within Head-Direct's thirty-day period. Careful though, you may end up keeping them both (they fit nicely in the RE1's case together), one for use with the T3 and one for use without it!
Originally Posted by ClieOS /img/forum/go_quote.gif The difference for me is, RE0 is 90% when unamped and sounds its best when amped, while RE1 is 70% when unamped and must be used with a neutral to bright amp to really show how well it can go. My worry is that maybe many of the RE1 users never really get the chance to amp it properly before deciding it wasn't for them. I always find myself lost in the sound of RE1 and 3MOVE, but never quite the same with RE0 (though I do really like RE0 detail). |
Originally Posted by ShenaRingo326 /img/forum/go_quote.gif i've been considering getting a set of PK1 and RE0/1... would the iBasso T3 be an adequate amp for the RE1's? my sources will be either iPhone 3G -- line out or the Clip+ -- headphone out for the iPhone setup i'll be using it in a quiet environment.. while the Clip+ will be for gym/travel thanks! |
Originally Posted by ClieOS /img/forum/go_quote.gif T3 should be fine, but do read about the difference b/w them before your final decision. |
