Radsone EarStudio ES100
May 26, 2019 at 12:18 AM Post #4,711 of 6,675
I don't understand what you're trying to do. There is almost nothing I know of that has a 3.5mm balanced plug. Not saying there isn't something, but it's not at all common. Balanced is usually 2.5, with some new stuff now with 4.4.
If you're getting a new cable, why not get the right termination for your use?
Hifiman and LH Labs use 3.5mm balanced output but you're right they're not very common. Especially not on newer equipment.
May 26, 2019 at 12:58 AM Post #4,712 of 6,675
AK, as in Astell&Kerns, is the company that first implemented a 2.5mm balanced socket. They don't use 3.5mm socket for balanced audio afaik.
May 26, 2019 at 1:51 AM Post #4,713 of 6,675
Thank you, I've edited my post above.
Enjoying the MT100 a lot btw :wink:
May 26, 2019 at 1:54 AM Post #4,714 of 6,675
Such a shame a good IEM can't get much (*any) attention in the forum.
May 26, 2019 at 5:16 AM Post #4,716 of 6,675
Said plain, 3.5mm single end cable (e. g. the ones that work with smartphones) never will work with balanced (like 2.5mm ES100 one). But there's no problem (with proper adapter) going from balanced to balanced, or from balanced to single end.
Like has been mentioned, 3.5mm balanced is rare and I find hard to believe that someone uses equipment that works with 3.5 balanced and does not know about it (plus the difficulty of looking for 3.5mm. balanced equipment), so don't buy 3.5 to 2.5 balanced until you're completely sure your cable is balanced too.
Best thing if you own ES100 and another source with 3.5 SE like smartphone is, as @rkw has said, to buy a 2.5 balanced cable (plus an adapter like mine if you want - 2.5 balanced female to 3.5 single end male-).
May 26, 2019 at 5:26 AM Post #4,717 of 6,675
Yep, couldn't agree more.
It does also sound great with the ES100 :wink:
May 26, 2019 at 6:01 AM Post #4,718 of 6,675
I already got this cable since months
If you get a 2.5 balanced cable, you don't need an adapter. Why do you want a 3.5 balanced cable? Do you have another device with 3.5 balanced output?
I already had this cable before the es 100
May 26, 2019 at 12:11 PM Post #4,719 of 6,675
Do you mean you have this cable that you posted earlier:
The pictures of the 3.5 cables have only 2 black rings on the plug and they are unbalanced. Does the plug on your cable have 2 or 3 black rings? If only 2 rings, then your cable is not balanced, and you can use it on the 3.5mm of the ES100 and you shouldn't use an adapter.
May 26, 2019 at 12:24 PM Post #4,720 of 6,675
It has 2 rings its not balanced is it worth to go balanced whit dm6 or tin t2 ?
May 26, 2019 at 5:41 PM Post #4,721 of 6,675
I have the Tin Audio T3, which is similar to the T2. On the ES100, I hear a small but definite improvement using the balanced output. Dynamics, detail, and definition are all enhanced. I think a balanced cable is worth getting, especially since you can use it with both of your earphones.
May 28, 2019 at 3:08 AM Post #4,723 of 6,675
Anyone with the new iphones (xs,xr) having issues with the bluetooth? My iphone 6s+ connects properly but I cannot see the earstudio listed in devices within the app. I can listen over bluetooth but I cannot pair within the app.
May 29, 2019 at 12:19 AM Post #4,724 of 6,675
Any news on the white/silver version?
May 29, 2019 at 4:42 AM Post #4,725 of 6,675
I could be wrong but I seem to remember they used to sell it but stopped for some reason.
