C_Lindbergh
Use https://www.mailboxde.com/ if you want it shipped to Europe from Amazon, worked great. In my case it costed like 10 euros extra and a couple of days more shipping time, But it was worth it!
Apple has no interest in aptX HD. They want to use AAC end-to-end, from the music file direct to the device with no intermediate transcoding. Within the Apple ecosystem, it makes technical sense.not for Apple though, they were obviously screwed by Qualcomm, not getting AptX HD, they'll probably pay for that later
Apt X was over hyped for sure, unfortunately it has muddied the waters.
Apt X isn't a great codec for quality, AAC beats it easily in terms of quality, but AAC is more expensive to decode, especially in low latency applications, not for Apple though, they were obviously screwed by Qualcomm, not getting AptX HD, they'll probably pay for that later but there are different opinions about what will happen next. I don't have a crystal ball for Apple, I don't get why they aren't even playing this game yet, possibly still pissed about hardware contracts they keep failing to hit (some might say they did it deliberately, but I think it came down to price). AAC is an excellent codec for lossy compression, Apple might just increase the bandwidth and continue using AAC, only increasing the specs when they want to achieve CD quality over Bluetooth.
AptX HD isn't a great codec, but the standard is a higher bit-rate than AAC can do over Bluetooth, so because of the higher bit-rate, AptX HD is better than AAC over Bluetooth.
On this ES100, Apt HD > AAC > Apt X > SBC
I'm just talking numbers here, which are objective - once the signal gets to the DAC, then it comes down analog and the ES100 is IMO, much better than most of what's out there, not as good as the higher end audio phones like the LG V20, V30, G6 etc... using their native 3.5 mm jack.
Some people's ears prefer hearing compression artifacts over signal purity, so it's also a matter of taste.
http://www.aviom.com/blog/balanced-vs-unbalanced/So, I'm new to audiophile stuff and was seeing a lot about the ability to use "balanced" cables/output on this device...can anyone give an ELI5 on this? I can't find much clear info on it online.
Sorry replied to the wrong message but you get my point hehe
I didn't claim they are technically ahead. Apple is focused on their ecosystem. Apple Music uses AAC file format and they can stream it directly with AAC codec, so they won't add other codecs (such as aptX HD) to iPhone/iPad. They don't care about playing your lossless file from another source. When Apple decides to do lossless audio, it will be driven by Apple Music in some format TBD, and they will update iPhone/iPad, AirPod, HomePod, and Beats to support playing it.Don't be fooled into thinking they are technically ahead, they just haven't pushed lossless yet.
Are you joking? The most profitable company of all time has enough cash reserves to buy Qualcomm outright.They couldn't afford AptX HD yet
Thanks a lot! The article says this is better for longer cables where noise is more likely; does it really have that much of an effect on shorter cables? (as in ones you'd have on most headphones?)http://www.aviom.com/blog/balanced-vs-unbalanced/
Similar principle is used on network cables (TP= Twisted pair, where noise affects both pairs and cancels each other out.).
ALAC is Apple Lossless, it's the equivalent of FLAC. That's what I rip CDs in as it Lossless and can play on my iPod in the car.I didn't claim they are technically ahead. Apple is focused on their ecosystem. Apple Music uses AAC file format and they can stream it directly with AAC codec, so they won't add other codecs (such as aptX HD) to iPhone/iPad. They don't care about playing your lossless file from another source. When Apple decides to do lossless audio, it will be driven by Apple Music in some format TBD, and they will update iPhone/iPad, AirPod, HomePod, and Beats to support playing it.
