waynes world
- Jun 21, 2012
The Firmware update is a zipped archive, of a Batch File that you run from a command line, and a couple of support files.
It doesn't require installing any software on your PC, but the Batch File does need to access the ES100, via a USB connection.
And make sure the es100 isn't being used (either by phone or by computer).
Hey DBaldock9, did you get the es100?
