skeptical
- Jan 24, 2015
Did you happens to notice which one of them was enabled when you had 100' range? Stable range on es100 is my main concern and 100 feet sounds quite amazing.
The option to change the Bluetooth codec is in Android 8 (Oreo). Your equipment list has Samsung S7 Edge, and Android 8 hasn't been released for it yet. Therefore you won't see an option to change the Bluetooth codec at this time. Android 8 is expected to be released for the S7 Edge, but probably not for a few more months. The S8 models are only just now receiving updates: https://www.sammobile.com/samsung-galaxy-android-8-o-update
For those who can't change in android - you can change in ES app. Not as fast switching, though.
Mine starts to break up right around 100' on both aptx hd and aac paired with my lg g6 and battery life and has been phenomenal while powering my IT01s.@antdroid Did you happens to notice which one of them was enabled when you had 100' range? Stable range on es100 is my main concern and 100 feet sounds quite amazing.
I found I couldn't even walk with my iPhone in my hand without drop outs.Maybe I got a defective unit, I have since returned it. 3 feet of range was just not acceptable. I really liked everything about it but if I can't use it for my daily commute, it's just not worth it. I'll keep an eye on this thread for the next iteration.Mine starts to break up right around 100' on both aptx hd and aac paired with my lg g6 and battery life and has been phenomenal while powering my IT01s.
At the moment, very much enjoying new and old technology: ES100 -> Fiio E12 amp (version 1 with great sub-bass boost) -> Sony MDR-V7 (circa late 80's). Very satisfying!
Have you tried any master track on tidal while on USB wired? I know ES100 does not support 24 bit input through cable connection. But, i am just wondering its behavior against 24-bit track.
i havent tried it for this application, but when I had a macbook in the past, WINE (WINE is not an emulator) was my best friend. That and Virtualbox for more functionality.
Do I need to actually own Windows for any of these options?
I don’t particular want to purchase Windows simply to update the firmware of one of my devices. Pretty sucky for Mac users otherwise.
Any chance for Mac support in the near future for firmware updates @wslee ?
Thank you!
EDIT: I suppose I could try updating on my work PC laptop — though worried my IT department will freak out. Is this firmware update “invasive”? Obviously that depends on each company.
Thank you!
