gordec
- Aug 14, 2006
FYI, this is on sale today with clippable coupon on Amazon today. Bought one for Note 10 since it's going to list headphone jack.
You seem to have a lot of good ChiFi cables but all in 3.5mm. You would need to repurchase 2.5mm versions. Then you can use with any 2.5mm sources, such as the ES100. If you want to use with a 3.5mm source like a phone then you simply use this adapter on the 2.5 cables:Can you please tell me more about that solution, looks interesting. May you show me a link/photo to the product ? (as I'm unsure)
When using your phone as a DAP, and wanting better sound. As is the case with me. That combination itself beats most of my daps. I'm sure a lot of the owners in this thread would agree with me when I say, you just have to hear the es100 to believe it. It's phenomenal.I’m failing to understand why I’d plug my IEMs into the es100 when I could just use the m0…
Ifi uses Burr Brown and the ES100 uses AK Chip. Both on the smoother side. The M0 uses a Sabre DAC which tends to be more analytical/less smoothed over. FWIW, I returned my M0 and kept both the Micro BL and the ES100. I prefer their presentations over Sabre.I’m currently using an M0 as a DAP and love it’s sound. At work I use an ifi nano black label connected to my laptop. The sound on the m0 is way more pleasing to me. With that said, would buying a Redsone ES100 and using it wirelessly with my laptop possibly give me a better sound/one closer to the M0 in sound? How does it do as a wired usb dac? Secondly, would the es100 paired with the m0 be useful in any scenario? I’m failing to understand why I’d plug my IEMs into the es100 when I could just use the m0…
I'm using my ES100 mainly at work connected to my computer as a DAC only and I have to say I don't ear any audible difference between LDAC and USB. For sure, LDAC is almost a lossless codec so USB still has a bit of technical advantage over it, but it's tiny.Have you used it as a USB DAC with a computer? Does it sound the same or is the quality somehow only especially good via bluetooth?
mostly all 2.5trrs should be ok but have to see what headphone u using like mine takstar pro 82 i have to find ppl rewire my trrs.Btw, if a 2.5mm TRRS plug has this exact PIN map, will it be compatible with the ES100 ? or will it short anything ? (looks like its different from AK)
That is the configuration for 3.5mm balanced TRRS (which is relatively uncommon).Btw, if a 2.5mm TRRS plug has this exact PIN map, will it be compatible with the ES100 ? or will it short anything ? (looks like its different from AK)
