Radsone EarStudio ES100
post-15124926
Post #5,131 of 6,070
HungryPanda
Kent, UK
Kent, UK
I have never had an AK player so do not know
post-15125039
Post #5,132 of 6,070
Mouseman
USA
USA
What might happen when I take a normal balanced cable, and use it with an AK player? Does this mean that my current balanced cables are wasted if I switch to an AK player?
You could use an adapter to make it an unbalanced 3.5 plug and still use your cable, but I've never seen an adapter that would switch it to the pin map shown above. It might exist, but I've never had to look for one.
post-15125109
Post #5,133 of 6,070
davehutch
Website
www.hutchinsonphotographic.com
Here's the diagram from the ES100 Radsone App.
Follow this and you can't go wrong
Reactions: scotvl
post-15125851
Post #5,135 of 6,070
Lurk650
South San Francisco
South San Francisco
Like I said 2.5 TRRS balanced will work with any 2.5 balanced source. You can't go Unbalanced (Single Ended, i.e. 3.5mm TRS) to Balanced 2.5/4.4 TRRS with an adapter but you can go 2.5/4.4 to Single Ended with an adapter. You can also go 2.5 to 4.4 with an adapter, that's what I do with my Sony ZX300. As I said, I buy all my cables in 2.5 TRRS then simply use the FiiO if I want to quickly connect to my phone or my iFi Micro BL, when using my ZX300 I use my iBasso 2.5 female to 4.4 male adapter.
post-15127227
Post #5,136 of 6,070
subwoof3r
France
France
Since I try to make full cycles to my unit, looks like I’m encountering a little issue about battery stats.
I try to charge to 100% but once the green led appears, once powered ON, the indicator seems to display 88%. I had to recharge again and after 5 minutes the green led appeared again and it was charged up to 92%, tried again without any success to charge up to 100%.
The « Battery care » switch from app was already turned OFF before this, so I tried to ernable it, reboot, and redisable it, then re-try and i twas this time charged to 100%.
Once it was at 100% I immediately let the device idle (turned off) for 2 hours, and after turning it on it showed 93% last. Not sure why ? looks like there is a bug in the battery management.
I triied using my unit for 20 minutes (until it showed 90%) but after turned ON later it showed 92% again.
Does this bug affects everybody here ? or do I have a defective unit maybe ?
Many thanks in advance
post-15127264
Post #5,137 of 6,070
tracyca
Do you have battery management on, if so it will not power the battery to a full 100% to save the life of the battery.
post-15127405
Post #5,138 of 6,070
Alphasoixante
New York, USA
New York, USA
It looks like my beloved es100 has bitten the dust. I bought it in July of last year and, I have to admit, I was not gentle to it. I'm actually surprised it has lasted this long! Before I lay it to rest, I'll describe what's going on and maybe someone out there has figured out how to fix it?
It randomly and frequently reboots. It doesn't matter whether headphones are plugged into balanced, unbalanced, or not at all.When the reboot occurs, most of the time it reconnects to my Galaxy S8+. However it takes a while to reconnect (much slower than when powering on). I recently updated firmware to latest and it seemed to stop the issue for a few hours, but it continues. Oh, and it also reboots when used as a USB DAC with my Win 10 PC. The one thing I'm realizing as I'm typing is that I haven't tested whether the reboots occur when music is playing, when it's not or both.
Anyhow, I'm very bummed.
post-15127709
Post #5,139 of 6,070
subwoof3r
France
France
Problem is that, as I said, I had the switch already turned off, so the issue looks like it don't really charge up to 100% although that switch is well turned off :frowning2:
post-15127864
Post #5,140 of 6,070
tracyca
Sorry about that I was quick reading in my kids school parking lot. Did not see that you had battery management off.
Reactions: subwoof3r
post-15128030
Post #5,141 of 6,070
subwoof3r
France
France
No worries! :)
post-15128083
Post #5,142 of 6,070
Slater
Cincinnati, Ohio USA
post-15128102
Post #5,143 of 6,070
gordec
Got the ES100 yesterday. I'm using it with Westone ES60 and Dita Oslo cable with 2.5 TRRS. The immediate impression is large sound stage. Where I feel it lacking is detail and dynamics. I'm using it in LDAC mode with Note 9 and in APTX it sounds about the same. So far I can't say it's better than straight out of the headphone jack of the Note 9 which BTW is a very good DAC. No one talks about it.
Reactions: bidn
post-15128135
Post #5,144 of 6,070
rbf1138
Just got an es100. Paired it with my iPhone but I’m getting some faint crackles when playing. Is there anything I should be doing to eliminate this, or anything I’m doing that may be causing this?
post-15128230
Post #5,145 of 6,070
Lurk650
South San Francisco
South San Francisco
@gordec yeah, Note 9 DAC is actually pretty solid. Still prefer to use the ES100 since I run balanced though.
Reactions: bidn
Users Who Are Viewing This Thread (Users: 2, Guests: 9)
  • Top
