arbiter76
- Jan 20, 2013
Dirty hole perhaps?
My ES100 just passed away sound is distorting and the only option is an out of warranty repair. I'm thinking the same exact thing -- or maybe even springing for the M9.
How are you using the ES100? Which phone/dap and app?
Update- I'm an idiot, didn't use the Bluetooth pairing on the app after the update. I guess it matters, no issues now.
Tidal has updated Android app and now it's able to play mqa files! Not only this, I can play first song of an album or playlist wired, pause music, connect ES100 and listen to the whole album, apparently conserving master quality
EDIT: It seems that when playing mqa files this way, not only it's possible to listen to the whole album/playlist, it's also possible to play mqa during whole session as if wired, changing playlist or listening to standard hi-fi tracks too in addition to mqa ones.
What codec is the EarStudio app displaying when you are playing MQA tracks on the ES100? I’m guessing LDAC or whatever other codec you have chosen to default to based on what the ES100 supports.
Sorry to be a party poopers but the MQA files you are listening to on your Android device aren't quite as beautiful as they seem. What I mean is that due to Android native SRC, all audio is being resampled to 16/48. So, though the original file is of a better quality than before, it's still being processed by Android software before reaching either upur headphone jack or Bluetooth device. The only devices that are doing bit perfect Tidal Masters audio are the LG V30, G7, V40. Granted, the Masters files resampled to 16/48 should rheoretheoret sound a bit better than the 16/44 files being resampled
Do you have another android phone you could test it on? I could ask my brother to download it on his and I’ll connect my es100 to try it out.So I got this and am happy with it so far with my Iphone.
Meanwhile I can not connect it to my Samsung Galaxy Note 8.
The app keeps on searching and is not able to find the es100.
Anybody having this problem, and if so knows the workaround? No issues with iphone, only Samsung Note 8
Just to be clear because you mentioned the app — are you trying to pair the ES100 with the Note 8, or already paired and trying to connect to the app? I've used the ES100 with different models of Samsung phones at work without a problem. Is your iPhone nearby while you're trying to do this? It might be auto connecting too quickly to your iPhone. Try turning off the bluetooth on your iPhone before you try to pair it with the Note 8.So I got this and am happy with it so far with my Iphone.
