A lightning deal is on amazon.de also. It's 75€ for about 4-5 hours.
There’s a significant usability advantage for me using my IEM’s with ES100 in my gym shorts pocket vs a wire connected to my iPhone XS, which I definitely do not ever put in my gym shorts pocket due to weight and clunkiness. The ES100 is orders of magnitude lighter and with the IEM cable under my shirt into the ES100 in pocket, it’s literally almost like having true wireless earphones to me, and I can change up what I’m listening to (or even watching) without my phone being physically tethered to anything.
I always laugh when I read someone opining that they don’t see the difference between plugging a cable into the ES100 vs directly into the phone!
Some phones have output impedance that's a bit on the high side for some IEMs, so this would be one good reason not to rely on the phone's 3.5mm jack, even assuming that the dongle solutions aren't otherwise superior. A wired DAC/amp stack will probably be the best from a quality standpoint (depending on the particular unit, of course), but is often bulky, which would bother some folks. Especially if connecting your your phone to your DAC requires cables that are proprietary and/or fragile and/or too long and/or with connectors that will be stressed whenever you put the stacked devices into your pocket.
Setup
- Audio Precision APx525
- Loaded (unless specified): 16 Ohm
Summary:
Supports high resolution playback up to 192 kHz.
Flat frequency response: <0.08 dB delta upto 96 kHz
Very good dynamic range: 93 dB
LOW output level: -9dBV (360mV using a 0dBFS signal) into a 16 Ohm load (for reference, Asian iPhone 6 = -1 dBV)
Output impedance: 5.6 Ohm
Crosstalk: didn't have to means to this measurement, sorry
THD+N: at nominal level = max 0.05%, at maximum level = max 0.7%
I've not experienced that yet but it's only have been 2 days of use.Do you ever get glitching on your 3T when using the ES100? I occasionally get a random cut in sound for a fraction of a second, the only way to stop it is the go into airplane mode and out again which stops it for a day or so. Very irritating. Pretty sure it isn't an issue with the ES100 after looking on the Oneplus forums
Excellent point. I found a post on xda-developers regarding the output impedance of my S7 edge and it appears to be maybe too low and THD kinda high, so not so good....
http://forum.xda-developers.com/s7-edge/how-to/s7-edge-headphone-output-measurements-t3336123
5.6ohm is actually really high (not too low) for a lot of IEM... The general rule of thumb is that output impedance at 1/8th of the headphone's own impedance gives appropriate driver clamping force (tho it's just a rule of thumb and not a law). Furthermore, multi balanced armature IEM tend to interact poorly with high output impedance because each armature reacts differently, leading to a wonky frequency response.
The difference between ~3 ohm output Z on my old Pixel vs 1 ohm or less on a dongle or the ES100 is pretty noticeable with my Massdrop Plus Universal IEM. I like using this kind of adapter because I just need one to pair with both my IEM and on ears as needed, and it's easily replaceable when it's outdated or the battery conks out. When the battery conks out on natively wireless cans you end up with a nice paperweight.
Recently picked up the ES100, and have paired it successfully with both of my Sony daps using LDAC. However, I am not able to use the volume controls on either dap. Do I need to update the firmware on the ES100? I did search thru the thread, but was unsuccessful in determining an answer. Thx for any advice.
Bern
Since the phone is just transmitting data to the receiver there is very little battery drain, less than when it has to decode, convert, and amplify the signal itself. Although I find that on modern phones the DAC/amp chips are so efficient that the battery drain is quite negligible too - it’s certainly the case on my LG V30 in spite of the powerful Sabre chip it includes.This question isn't specific to the ES100 but is there a significant battery drain difference between using a phone directly vs. using Bluetooth and a receiver? Maybe a dumb question but I don't really ever use BT devices.
