Lurk650
I have the Amiron Home, same 250ohm/102db sensitivity. I have run them balanced from the ES100. Got enough volume but still wasn't that dynamic. Running them single ended I'm sure you will have a worse time unfortunately. The ES100 is for easier to drive gear.Has anyone done testing with ES100 and DT1770? Is ES100 enough to drive the 250ohms in a DT1770?
I have done some research and a few members here have provided helpful directions.
But I am a bit confused with the 2.5mm vs 3.5mm power outputs. As I understand the DT1770 is an unbalanced headphone and will be driven by the 3.5mm output of ES100. Is this correct? Or will I be able to leverage the higher output of the 2.5mm output even if the headphones are unbalanced?
Thanks!
