monsieurfromag3
What will you plug on the other end of that beauty?Just got the balanced cable for my new ES100. It has arrived extremely fast from Penon Audio
Hey Swedish guy! It was my setup, the A&K SP1000 Cu connected to Rhapsodio 2.98 cable and Empire Ears Phantom.Hi! Swedish guy here
Can you ask your colleague what IEMs he let me try? Im reffering to your custom molded ones. They were on another level! And what DAP was that?
Hope you will enoy the ES100 as much as we are!
Just want to give a quick shout out to @Adventure and the guys at Hifisolutions. Wonderful store and people working there. Great products in stock and for testing. Super friendly and helpful!
Best hifi store-visit for me by far!
Windows 10 natively supports Apt-X although it might be difficult to know it exactly when you connect via bluetooth.
you got ldac working on android nougat just due to the firmware update?
With all respect to Sony for product details - WH100xmk2 is very average sounding headset which can't even properly hold bass. Any Beyer should be killing it.The previous update contained the LDAC upgrade for the ES100. I have Oreo on my V30, so it already has LDAC. Once I figured out the correct timing to hold the power button down and instantly plug into the computer, windows recognized the adapter, and I ran the firmware update without an issue. It sounds even better than it previously did. I just tested it again against a Sony pair of WH 1000x mk2, and my Beyers sound just tons better.
For those people a few pages back saying they wanted a metal unit instead of plastic, you might want to take a look at the Ampio VS-1880. It's just a straight up receiver/DAC and doesn't have an app or anything and is only 3.5mm but it's a great sounding device with aptX HD and LDAC. You can check out my review of it here: https://www.head-fi.org/showcase/review/20615/
As for the ES100, mine just arrived today so I'll be able to test it when I get home tonight. Am looking forward to it after hearing all the praise it has received.
And btw - no need for any timing during update - press power button and hold it and while holding it - plug usb in.
Getting a balanced cable for your DT1770 won't be possible unless you modded your DT1770 from a single ended mini-XLR that has both the left and right channels contained, and change to a headphone out that separates out the left and right channels as well as their ground cable. These mods can be costly and will void your warranty. This is the same situation with many AKG and other Beyerdynamic headphones.You know, customer service said, but I tried it like 10 times and the only time I got it to work was press button and instantly plug in. If you wait on a 3 Count or something, then it do any work.
I agree on the Sony. They sound decent (better than Bose, V Moda, and many others), but just not quite there. I have DT 1770s with a1 foot mini xlr cable going to my ES 100. Looking for to upgrade that to a balanced cable with right angle 2.5 jack. Not sure where to get one . Maybe custom cans...
You're correct you would need to mod the internal wiring. The DT1990 have the same challenge. The only headphones in that price range that I know from Beyerdynamic that can support a balanced output without modification are the Beyerdynamic Amiron Home, but these are open back. I do not know of a closed back headphone from Beyerdynamic that supports balanced out without modification.So I would need to mod the internal wiring? Are some headphones made that are already balanced, or is it always a mod?
