blomman77
- Dec 30, 2011
Ok,but do you have to change the values manually,or does ES100 "sense" the IEM you connect?Saves for me and changes calcs.
It's in the wiki - "design is based on time domain ADPCM principles without psychoacoustic auditory masking techniques" And bits allocation per subband is fixed.
They only have a dynamic range adjustment so they encode low volume tone without high volume tones more effective.
It's based on this patent https://patents.google.com/patent/EP0398973B1 - if you see here anything that would show that multi-tone test is more useful - let me know, I could be missing something.
In my understanding, 2 tones with the same amplitude in different subbands would be exactly the same.
Manually. It's just a calculator.Ok,but do you have to change the values manually,or does ES100 "sense" the IEM you connect?
Here is a quote from the above mentioned patent "The signal in each sub-band is coded by means of a linear prediction technique and each sub-band is quantized with a varying number of levels according to its signal variance."
That's not fixed.
Further down in that patent "The aim therefore of sub-band coding is to allow the bit distribution to match that of the signal variance within each band, and in doing so, maximizing the likelihood of noise masking. Obviously the spectrum pattern of figure 6 will change with time, implying that an even greater gain could be achieved by allowing the bit allocation to adapt to the short-term energy in each sub-band, figure 11. This process is known as Adaptive Bit Allocation in the frequency domain."
That's complex, but it's not even a small portion of the complexity in that entire patent.
Getting back on track, regarding using multiple tones in testing the noise associated with each codec, it was a suggestion based upon what their testing equipment is capable of, the generator may not be able to make a signal complex enough to challenge the codecs efficiency, but at least it might get it closer to avoiding the rather unique case of encoding a single sine wave - that's like comparing 7zip and WinRar by compressing a file of 20 bytes length.
With the es100 off, open the update app until prompt to connect! Then press the power button and immediate connect it to any usb port! You should hear the windows bell of a device being found.Anyone else have trouble updating firmware? I have the correct cable type (data), plugged in, hold button down, but DFU cannot find it, and so won't update. I am pretty stoked that it got LDAC, but I don't believe I can use it until I update the firmware (or at least it won't currently connect with LDAC, and only connects with Aptx HD). Help appreciated.
I got it. You have to press power and plug into cable simultaneously or it won't work. Really picky. Got that LDAC!
also, if i use my PC to connect to the es100, how do i know what bluetooth codec its using or can use? I dont see any downloadable software for windows bluetooth functionality.
Hi! Swedish guy hereOk after a Swedish guy came in our store in Amsterdam with the Radon EarStudio I ordered one today, to check it out myself ..
Will let you know how it goes, it looked like a great companion for an head-fier!
