mhoopes
Hd650 is somewhat not loud enough at maximum voltage. And with 846 you need really low resistance cables while most balanced cable is 10x higher than they should be. Balanced still useful to remove ground noise issue and increase channel separation. I have to use 1x balanced voltage mode (can't hear any difference of 1x or 2x voltage) and -23dB analog volume with -6dB preamp to use 846.
When you say -6 dB preamp - where do you adjust that on the ES100? Is that the source volume?
Also, what gauge and length wire are you using for your balanced cable? Last I checked, 28 AWG wire was about 0.064 Ohms/ft, 24 AWG 0.026 Ohms/ft.
