@wslee
1. Can you create an iOS lockscreen widget that gives access to the analog volume control? Opening the app each time to check the analog volume is frustrating.
2. The physical volume buttons do not respond to rapid presses - I must wait for a delay between each press to change the volume accurately, or press and hold and to quickly change by an unknown amount.
3. Can you add an option to allow iOS volume sync? I don't care about granularity - the invisible analog volume control is just annoying to me. Maybe allow setting a maximum limit for the analog volume so the iOS volume steps would be divided over a smaller range.
