PiSkyHiFi
- Dec 15, 2009
I don't like that feature (sorry). I have the LG V10 and V20 (I see you too) and it bugs the hell out of me that these things are deciding on their own which gain/votlage mode they set. Because as you rightly say: it's an estimate. My planars have low impedance but need a lot of power - so the autosensing is always choosing the wrong setting - so do some of my dynamic driver in ears, I really like that we can set the voltage ourselves manually and not rely on some autosensing stuff
Cheers
No ones implying that you are forced to use a setting that doesn't work properly, or even one that does.
My suggestion is that you can set an option to allow this current profile to be auto-selected if it matches an impedance class - the starting position is none of these flags, one for each profile, will be set to auto-select.
It all hinges on being able to get a reasonable estimate of any particular impedance class that can allow some headphones to be easily differentiated.
If it can. it would be a smart feature to have, especially for a small, already smart audio device.
