Copper wire. MMCX connectors, 2.5mm L connector.
~75$, price to be discussed with Ted
It should workMay I ask, can I connect the ES100 through a speaker and AV receiver with a 3.5mm to 3.5mm? Will it kill my es100?
I'm very much digging my balanced/removable cable modded DT1350 with the ES100 and my Samsung S9 via LDAC. The Dragonflies and every other USB thumb DAC/Amp I've had are history since owning the ES100. I'm assuming from the ES100 app and Neutron, the 24/96 albums are supported from end to end.
I haven't tested it yet, but can the ES100 internal battery be charged from a battery bank while on with music? A nice accessory for prolong playback would be a very small and portable (half the ES100, maybe?) micro battery bank to piggy back at the bottom of the ES100 via the usb port.
I think it should technically work. Although why would you do that? Is the intention to charge ES100 nonstop? That would mean wasting the battery cycles.
This is my “portable” around the house setup
Yeah these are the dekoni ones. I haven’t switched back to the stock ones yet as I want to get a good idea of the new sound. I’ll write up something this week in the Elear thread about it.Nice one... quick question .. is that the fenestrated sheepskin pads for the Elear? Are they a worthwhile change?
@wslee Is there any way to have the ES100 get an estimate of the impedance of the attached headphones?... if there was a way to do this, you could implement volume profiles for the ES100, where the eq and preamp settings can be stored separately for each class of device attached, like an adjustable pre-set for the sound profile of each attached headphone.
Sound profiles for different headphones are a much needed feature for any DAP, but it makes even more sense in a device like this, you could allow the user to keep a list of known eq+preamp profiles, like you currently have for just the eq, 4 pre-sets is very useful, and setting the name is actually really great idea someone here had too.
Just need to change the profile to include the pre-amp as just another eq setting, so it's stored with its eq profile. - edit... oh, it does this already!!! no problem.
If you could add a default class to the creation of a profile based on the estimated impedance and allow a profile class to be automatically selected when that particular device is attached, you can add the ability to auto-enable a profile for an already known device.
I think this would be a great addition to this great device, take it's practicality to a new level.
Anyone else think this would be a great feature? Volume profiles?
No, I dont see the need for this myself. Starts to overly complicate a nice simple device.. Never have seen such a feature in and DAP; even expensive ones.
Hi,
a question from a happy new owner of the fantastic ES1000:
Is there a setting to adjust the left-right balance? I could not find any in the app.
If not I would greatly appreciate that a setting for the left-right balance would be implemented. (my left ear is a little less sharp than my right one)
BTW:
- superb sound for such a tiny device
- I love the possibility of setting the AKM DAC filters!
- beautiful equalizer
- when updating the firmware I could not find the dfu zip file which is mentioned in the manual, but actually it was not necessary
- I am exited about testing LDAC and comparing it to AAC, I should be able to do this tomorrow.
Many, many congratulations, wslee !
