chrisyak
Member of the Trade: Headphone Flipper and Reviewer
Don't get me wrong. Most of the users here have above average dacs and amplifiers. You don't get to Immanis level to by being happy with a crappy chain. The amanus can be driven by some pretty weak equipment. However, that does not mean that in order to get the very best out of these headphones that you should not try using better equipment. Some equipment is underpowered but delivers really great results. It's all about how it's put together.Maybe a slightly unusual approach there Chris. Immanis only needs around 3w I think Alex said previously. With Envy + Immanis most users are already dropping DAC output, I have mine just over 1vrms into Envy (around -14dB on M21) and when straight into XA30 it's just over half that (-36db) The XA is around 7.5w per channel at 32ohm but has an input gain of 26dB which will blow your socks off compared to Envy using the DAC as pre.
With the 590, I'm only assuming you had volume at 12 and started on lowest gain working up to what was a reasonable volume around 12 on the pot? (think 590 is the same as US5+ and it'll have gain dip switches on the back?)
What gain settings did you use with the 465?
I have a really great example of that. The T+A HA 200 which I would call one of the top five solid state amplifiers in the world. It has a built-in DAC and it is just amazing. It drives almost all headphones perfectly. However, I found out that it does not drive low impedance headphones at higher volumes very well. Does that make it a poor product.No. does it mean you cannot play it loud, no. What it does mean is that for a very small percentage of users that like to play their low impedance headphones at borderline deafening sounds the amplifier /DAC is not able to keep up with others because of this flaw in the system. 99.9% of listeners may not even experience this issue. Some people may not even call it an issue. However, there is that 0.01% will experience this issue and will find it unacceptable. They will need to find a different pieces of components in order to drive low impedance headphones at the levels they like. I also believe that components that are able to drive more ampage and voltage to the headphones are able to get more out of headphones then underpowered devices.
For me it is an issue and it has sent me on a mission find chain that is not impacted by this issue.
Call me picky. Call me crazy but I like to listen to my music very loud and I like to have a lot of power behind.
The gain settings are going to help but anything past medium is going to introduce levels of distortion which I am not fond of. I can of course increase the gain settings and blow the headphones or my eardrums but that doesn't do anything for me. I want to be able to listen to the music at eardrum shattering levels and sound as crystal clear at reference sound.
