normie610
Late Saturday night session with Eiji Oue's Reveries, fibre optic, twelve tubes and Immanis. Sublime.
Thanks buddy!Lovely setup and lovely photo! Obviously taken with a Hasselblad…
I’ll add Eiji Oue’s Reveries to the list to check out!
Definitely, I was very much generalizing and didn't mean to speak in absolutes that SET is never good with Immanis. My Willsenton 300B/805 speaker amp sounds great with Immanis for example and that's SET. I think just because it's so overkill on power, it's sharper than a lot of smaller SET amps.There are a few exceptions to this, and that includes Primavera. It’s a SET amp, but it’s far from being too tubey. Perfectly balanced and clean sounding but still retains that euphonic tube sound and “roundness” to the notes. A perfect pairing with Immanis.
so, this morning I made the change of the 4 el34, 4 mullard xf4 of Blackburn took the place of the 4 Psvane el34 ph Replica.
This weekend I will deepen their sound.
The other 2 el34 are always Mullard, but xf4 of Brussels with double square getter.
Over the last 300+ pages of this thread there has been plenty of valuable feedback about how users feel their gear pair with the Immanis, and a pattern has now taken shape very clearly. The vast majority of owners, myself included, believe that the best sonic results are obtained within systems (source + amp) having some degree of warmth and densifying coloration w.r.t. a dead center neutral ideal.
And, while in most cases we speak about synergy but we actually mean to fix shortcomings in certain components of our systems by acting on others, with the Immanis there is close to nothing to really 'fix', and synergy is mostly an exercise towards making them sound from great to spectacular, or closer to our subjective sonic balance preferences.
I received my silver pair about a month ago and I'm still going through brain burn-in. I have the CA-1a so I'm familiar with the ribbon sound, but Immanis required me some getting used to. I mostly listen to metal, so the recording quality is usually not great. Immanis is very ruthless with poorly recorded albumsUsing the SC2 cable instead of Star-8 provided some taming/mellowing and so far I like it better. I'll gradually try switching to the Star-8.
With the AIC-10, my favorite tubes currently are the Mullard 10M and M8136.
Speaking as someone who also listens to a lot of metal, that's true--the Immanis is very transparent, so imperfect recordings will stand out like a sore thumb unless you mitigate it with something else upstream. A tube DAC, preamp, or a full tube amp may be in your future--my guess is that a cable alone won't be enough. (AIC is awesome, but if you need to smooth out bad recordings, something that adds more softness than a single tube can provide might be in order).I received my silver pair about a month ago and I'm still going through brain burn-in. I have the CA-1a so I'm familiar with the ribbon sound, but Immanis required me some getting used to. I mostly listen to metal, so the recording quality is usually not great. Immanis is very ruthless with poorly recorded albumsUsing the SC2 cable instead of Star-8 provided some taming/mellowing and so far I like it better. I'll gradually try switching to the Star-8.
The difference between Star-8 and SC2 is not huge, but I guess SC2 is maybe less resolving and that makes it sound like mellower? Not a great example, but if you've ever tried the 1266 TC with a silver cable and then the stock/Superconductor, it's similar to that. I’m also still testing some EQ and that seems to be helping even with a simple low shelf.The Immanis isn’t very forgiving, but to me it doesn’t automatically make things sound bad if it’s poor quality. It’s just… revealing. I’d be curious to compare the SC2 cable to the Star-8. Care to share more impressions of it?
I should join the next Denver meetup when Danny brings the Viva 2A3 for sureSpeaking as someone who also listens to a lot of metal, that's true--the Immanis is very transparent, so imperfect recordings will stand out like a sore thumb unless you mitigate it with something else upstream. A tube DAC, preamp, or a full tube amp may be in your future--my guess is that a cable alone won't be enough. (AIC is awesome, but if you need to smooth out bad recordings, something that adds more softness than a single tube can provide might be in ordered).
If I remember correctly, you are from the inland empire, maybe riverside? If you make your way out my way, to Orange, you can check out the Mola Mola. You can also check out the Cayin Soul while you’re here, too!
I have a 10 month old in the house, so one thing I like about the AIC is there’s no tubes to touch![]()
@chrisyak i was going to recommend trying mola mola. I think your money is better spent on a DAC than a streamer/dac combo.
I might be meeting up with aetherhole next week. @theveterans when do you want to hangout? Or come to our LA meet next month and try some stuff.
Is the Immanis better suited for power amps then other HPs because using the transformer eliminates those impeadence mismatches one would otherwise have? Meaning if one uses speaker taps with way higher let´s say 60 Ohm HPs diminishes the power provided by the amp making the amp potentially "too weak"?Just trying to get a better understanding for myself
I wish I can find Sansui amps here but it’s just impossible to find one. Are you using the TI-1b or the RCD 32 ohm interface with Sansui?At the other end of the spectrum I love how Immanis sounds on my retro Sansui amps which are 100% solid state. They use vintage MOSFETs which provide a pleasant richness.
It does.Is the Immanis better suited for power amps then other HPs because using the transformer eliminates those impeadence mismatches one would otherwise have? Meaning if one uses speaker taps with way higher let´s say 60 Ohm HPs diminishes the power provided by the amp making the amp potentially "too weak"?
In other words if the XA30.8 provides 30W @ 8 Ohm (disregarding preamp or Bricasti power setting) then with the correct Immanis transformer you are able to use all of it and instead with a mismatched HP you loose power?
Or does it not work like that?
Yes, you absolutely should!!I should join the next Denver meetup when Danny brings the Viva 2A3 for sure![]()
I imported all of mine from Japan. I use the TI-1b's 16ohm input. Speaker amps generally expect lower impedance, typically 4 to 16 ohms.I wish I can find Sansui amps here but it’s just impossible to find one. Are you using the TI-1b or the RCD 32 ohm interface with Sansui?
