Aug 2, 2024 at 11:07 AM Post #406 of 448
Yes, Sorry. I meant CMA 15. I thought it was the best place to ask, since that'd be a question for the people actually owning the desktop iteration (either the desktop CMA 15 or 18)... Anyway....
I have both a 320MAX Ti and the CMA18 Master and I’ve had both for a while.
The biggest jump is in the staging. The stage is significantly larger and notes have much more space to “breathe”, so to speak.
The resolution is mostly similar. If anything, the 320MAX Ti may sound more detail oriented. I have heard that the Questyle CMA line-up is more known for their amplification than their DAC stage, so maybe that’s why there isn’t a clear difference in resolution.
I’ve also tried amping the 320MAX with the CMA18 which was fun, and I may get a dedicated DAC in the future. The CMA18 Master is a flexible system which I appreciate. For me, it was a good entry into the desktop space.
Aug 2, 2024 at 11:16 AM Post #407 of 448
Thanks for your detailed answer. Very helpful indeed
Sep 12, 2024 at 11:20 AM Post #409 of 448
@Questyle I have a pair of 300 ohm headphones and I’m concerned about a possible impedance mismatch. What is the output impedance of the amp?
Hi Smirk 24 --
Here are the headphone amplifier specs for the CMA Fifteen Master, taken directly from the latest promotional materials in July.
6.35 mm: 188 mW @ 300Ω
4.4 mm balanced / XLR 4-PIN balanced: 765 mW @ 300Ω
THD+N <0.0003% @ 300Ω
So I believe you should be fine with your headphones.
Cheers!
Mike
Questyle Audio Engineering Stay updated on Questyle Audio Engineering at their sponsor profile on Head-Fi.
https://www.facebook.com/questyleaudioeng @Questyle_Technology https://www.questyle.com info@questyle.com
Sep 12, 2024 at 11:34 AM Post #410 of 448
Hi Smirk 24 --
Cheers!
Mike
The Fifteen Was never made as a Master version.
Sep 12, 2024 at 2:03 PM Post #412 of 448
300 ohm means you won't have any problems with impedance. Where you have problems is when impedance gets low (like really low, sub 10 ohm impedance). Enjoy!
Oct 6, 2024 at 7:39 AM Post #414 of 448
Hey everyone!
My CMA Eighteen arrived last night! I'm currently burning it in with my new HD-800S and new HE-1000se, and I'll post a review in the dedicated thread a bit later.
Also, has anyone noticed any changes in its sound as it burns in?
Thanks!
Oct 6, 2024 at 7:42 AM Post #415 of 448
Yes, mine changed after the burn in
Oct 6, 2024 at 8:49 AM Post #416 of 448
Hey everyone!
My CMA Eighteen arrived last night! I'm currently burning it in with my new HD-800S and new HE-1000se, and I'll post a review in the dedicated thread a bit later. In the meantime, I wanted to ask CMA Fifteen owners: can I use it 24/7 without a break, or could that be harmful? I'd like to leave it running overnight to burn in my headphones.
Thanks!
My HEK SE was a bit too shrill with my Fifteen and Twelve Master. How you have some warmish cabling.
Oct 6, 2024 at 9:21 AM Post #417 of 448
No, I only have the stock cables at the moment. I'm currently listening to them on the 18th Master using the balanced cable. The headphones have been playing for about 40-50 hours, I don't know if the sound will change in any way later on.
So far, this is the situation: if you listen at a comfortable volume, they don't sound bright. But if you turn up the volume and play, for example, rock music, they can start to sound harsh in the upper mids and become fatiguing.
The 18th Master seems to be very powerful, because I'm currently listening at this volume level (and in addition, I have to lower the volume in Audirvana on my MacBook Pro M2 by -13dB!). If I listen in 0 dB mode, then I can hardly turn the volume knob at all, it stays at the minimum possible position.
Do you have any experience with different cables for the HE1000se? If so, could you recommend any proven models?
I've attached two photos. The first one shows the volume when I reduce the power in Audirvana to -13dB, and the second one shows it at 0 dB.
1.
2.
Oct 6, 2024 at 9:27 AM Post #418 of 448
1.
2.
You can use it also at low gain, there are 4 switches under the 18M
Oct 6, 2024 at 9:28 AM Post #419 of 448
1.
2.
Gotcha.
I suppose you could stay away from silver. Just stay with continuous cast copper. All cableing will make a difference. Power cords, interconnects and headphone cable.
You can look at Artic Audio for headphone cable. I've had good success with his stuff. He's not the only player in town, I'm just saying you can investigate.
Oct 6, 2024 at 9:35 AM Post #420 of 448
Thank you so much! I'm so glad I registered on this forum because, to my shame, I didn't realize there were gain switches on the bottom of the 18th. They were all in the "standard" position, I switched them to the "low level" position - and it's a completely different experience, it had a very positive effect on the sound.
I'll check how this affects the brightness, because it's more comfortable to listen now.
Gotcha.
You can look at Artic Audio. I've had good success with his stuff.
Thank you so much for the recommendation, I'll start looking at copper cables and that brand you mentioned.
