GL1TCH3D
- Apr 10, 2011
I tried the sr009 with the wes at SSI and it sounded bad compared to the sr007 =/
Yes it is a common practice on tube amplifier.
I'm suggesting an iPod because as I've said before, I do believe a quality source shortens the gap in SQ between amps being used, whereas IMO an iPod shouldn't do that.
This probably sounds an idiotic suggestion, but when testing and comparing not just the LL and BHSE, but any amps, the source that should be used is an iPod. Yes it does sound daft but when I took my BHSE and 009's to a head-fi meeting the source I took was my iPod, ( my main source weighs 33kg and I've only got it insured via my home insurance ) and all that had a listen were very impressed.
I am saying it depends on the person. Some tastes will prefer A, the LL, over B, the BHSE. Those same people will likely prefer A over C the KGSSHV irrespective of B being better or worse than C because B and C are related. If they prefer B to A, it could well be they'd also prefer C to A, again not because if B is better for them than A and is better than C as a given then C must be better than A - rather it is simply because B & C share characteristics in sound that A does not possess.
I disagree. A good source is in part resolving enough that you can hear when and how much the amplifier or transducer is a bottleneck. Good sources do not lessen the gap, unless they are highly colored.
In the case of the ipod, the output V is so low I'd suspect that would be the largest reason for hearing a difference in between amplifiers, which is not at all what you would want to assess to figure out a qualitative difference between amplifiers. Its kind of like saying "this one can go louder so its better."
Come on, lets face it, if it wasn’t for the enormously long waiting line for a BHSE we’d all own one.
