TimOgawa
Totally busted
- May 18, 2013
I have un-jailbreak iPod 2G with the iOS 4.2.1. What is the best apps for EQ? or any other apps that involves Player
Which EQ app would best fit this criteria? ...
1. Gapless Playback
2. Library functions simliar to stock ipod player
3. great sound (obviously!)
I have accudio, sounds good but i don't like the interface much,too fiddly and buggy and no gapless playback. I also have the free Denon app,which works well i like the interface, as it's similar to the itunes one,easy to use but no gapless...
What do you think i should try next?-I listen to lots of dj mixes, so gapless is very important for me.
Thanks. Could you confirm whether equalizer has gapless playback?-I can't see anything about it on the info..
Just had to try it. It does have gapless playback, and it's great!![]()
Thanks for the recommendation.
Lunatique said:
Accudio is far from being neutral. The people behind it don't really understand what neutral is when it comes to headphone frequency response. I wrote a post detailing what the problem is here: http://www.head-fi.org/t/644688/the-accudio-app-by-golden-ears-a-headphone-revolution/60#post_9304107
As for all the apps that are processing the audio to "enhance" it in any way other than your own custom EQ curve, my advice has always been to stay the hell away from them, because it's no different than just randomly slapping a mastering plugin onto your audio bus instead of addressing the exact deficiencies of your specific headphone. The people who make these audio enhancing apps have no idea the exact headphone model you're using, so it's extremely likely that whatever "enhancement" is going on is actually exacerbating the already problematic areas of your headphone's frequency response. Apps that claim to have unique custom EQ curves for specific headphone models (such as Accudio) are only as good as the people who are behind them, and Accudio is NOT what I consider reliable and authoritative. I have no idea if Audyssey's take on the idea is better--I'll have to try it and see, but there's no free version to try like Accudio.
To date, the only sensible solution I've seen, is to EQ your headphone according to its specific frequency response measurement (can be found on reliable, authoritative websites like InnerFidelity). A straightforward parametric EQ with an intuitive GUI that allows exact input of frequency, bandwidth, and gain, is still the best solution. And Equalizer is still the best one, considering all that.
1. Gapless Playback
Well I still use it as my main player at the moment,because I like to eq the sub bass,but if I didn't need eq,I would definitely go back to the stock player.
It's quite similar to the stock player in terms of searching,but a bit more fiddly to use,and it has a tab in the middle that is too tall that covers up the words 'songs' and 'albums'(hard to explain without seeing it!).I asked about this and apparently there is going to be a new design later this year,so hopefully that will change.
I'm still looking for an app that is identical to the stock player,but with eq though...
