"I heard both headphones as essentially identical" Tyll (Innerfidelity) comparing K701 and Q701
Must we keep going over this again and again.... They can both be dry/thin or warm/full depending on how they are amped, burned in, pad wear etc.
You can't have that much change as you have described without changing the drivers or the design of the headphone. They are the same drivers within the same designed headphone. Identical, apart from the colour and a little button that sez Quincy. Don't be fooled by the clever marketing!!!
I'll use my guitar analogy again mind!
This has already been debated to death.
AFAIK, no one has disassembled the Q701s to see if they're actually identical. Yes, I know the service manual says they should be. It's possible the Q701s have some different damping on the
back of the driver.
I was skeptical too that they could sound different, for the same reasons you are. It doesn't make sense that they would sound different. I didn't want to keep going over the debate again and again, so I ordered a pair of K702 to compare directly to my Q701 myself. The pair I compared back to back, A-B, on the same setup, etc. DID have all the changes we've been describing between about them (I think you've already seen
that thread). I was surprised that the difference between them was as large as it was. I was expecting a minor difference that could be attributed to variation in production, but the difference I heard sounded intentional.
I don't know why my pair was so different. I'm welcome to suggestions. I'm not a huge believer in burn-in. The Q701s were bassy and warm for me out-of-the-box. I was surprised at how much bass they had the first day I put them on. Both AKG pads look pretty new and identical. I doubt any subtle changes between them could add several dB to the bass.
I know others like Tyll have heard them the as sounding the same.
That to me is the confusing part. If he heard the pair I heard, I guarantee he would have wrote a completely different comparison. The only thing I can think of is AKG has had some variation in the x70x over time (intentionally or unintentionally?...) That could explain why some sound the same, and some sound different....
I could probably take apart the Q701 and look at the insides. I've taken a K400 apart and the Q's look similar. But the Q701s are my babies, and I'm scared!!
