- Mar 20, 2010
Which is why something like Fiio D3 is a must.
You'd need a conversion of digital to analog somewhere in that mix
Watching Tyll's review on Youtube implies they sound identical (as well as IF's graphs), but headroom's graphs, you and a few others think otherwise.
Not sure what to think. I wish you had the DT880s on hand to compare, but oh well...
Its almost like AKG revised the Qs recently to differentiate it a bit vs the Ks...
@Alkhe4life, I can strongly reccomend the iBasso D6 for the Q701. I heard a friends a while back and was able to budged my setup down from a lyr bifrost combo to the D6 and still be happy. No the D6 isnt as amazing as the lyr bifrost combo but dam does it drive the Q nicely. With the D6 you get a 24/96 wolfson dual dac and a potent amp which is what the q needs. if later down the road you want a better amp you can still use the d6 as your dac and plug the d6 line out into your new amp like i do with my objective 2 amp.
Hope this helps.
-M
Yes, the 3.5mm jack is already amped by your soundcard (every standard headphone jack is amplified), so hooking up an amp to that is double amping, which is potentially worse than not using an amp at all.
Even the iBasso D12 works quite well with my Q701 cans.
I bought it based on the three flavours of digital input: RCA, Optical and USB.
M.L.E., I've been eying the D3 as an inexpensive stop gap until I can afford something nice. How do you think it compares to the E7's DAC section?
The D3 is superior to the E7. A fuller, clearer sound. It adds a little bass emphasis (very,very subtle) compared to the E7.
For the price of admission, I highly doubt you'll find anything to hate about it.It sounds damn good.
