Shazb0t
- Dec 25, 2012
What follows doesn't apply to the Q701 but to the HD650 and will vary depending on what dac used:
The O2 can be funny w/ some dacs because of the impedance of the ODAC. I had bass distortion w/ the HD650. I contacted John at JDS labs and wrote the following: " On high gain, the O2 is breaking up with my HD650. The bass gets crackly and distorted, especially around 60hz at -10 db. Other frequencies give it trouble on some songs too. I had to wait to get another amp to see if its definitely not my DAC and not my headphones. Is this just the O2 being maxed out or is there an issue with it? With another amp, the system does not have that problem..." John was helpful and responded: "
This occurs with O2 when using a strong source/DAC with some headphones. You simply need a higher voltage AC adapter to use high gain. More information can be found on the instructions guide." And here is a link to the PDF:
http://www.jdslabs.com/pdf/Instructions_O2.pdf
(Search for distortion)
In other news, the Magni would have to be the clone of the O2, since the O2 came first! But don't worry...it's not!
High gain on the standard o2 is for use with portable sources that don't have high output. If you want to use the o2 with a standard output DAC then you should clip the resistor on your o2 giving you unity and medium gain option.
