ericr
- Apr 19, 2008
In addition to low and high gain, the Ember II has Input Attenuation via a small plug-in resistor pack, that further lowers the output level.
I use my original Ember 1 with various IEM (including 1964 Ears - pretty efficient/higher sensitivity). Initially, even on low gain I would barely move the volume knob much past 8:00 and had some channel imbalance. Being the cool guy he is, Jeremy had me send it back and he did a mod to replace a couple of resistors with some higher value ones. Post mod I typically run with the volume knob in the 10:00 to 12:00 range.
Not too long after Jeremy released the Polaris and then the Ember II, both having the plug in resistor packs so users can do this mod themselves (no need to ship it back or for Jeremy to desolder/resolver components).
Let Jeremy know you're using IEMS so he can make sure you get a couple of resistor packs of different values to try out.
The Ember is excellent with multi balanced armature IEMS.
