HiHead Hunter
- Apr 25, 2016
While I don't have a 6SN7 Sylvania, the other 2 tubes are quite similar in the Ember. I think it takes a little time to get used to listening for the slight differences in tubes, many say that this or that tube is a big improvement but in my experience the differences are quite subtle most of the time.
A great learning tool is the Golden Ear program (just found out that it was shut down)
But you can try this: http://harmanhowtolisten.blogspot.de/
One way of listening for the differences is try changing the output resistance/impedance on the Ember with the HD-650, you will need to adjust the volume also but you should be able to hear the slight differences in the how the highs are presented and how the tightness of the bass is affected. You can change the jumper setting while the amp is on so the changes happen in real time, just try to match the volume as close as possible.
Thanks for that link, I'll check it out soon. Indeed I have experimented with the output resistance settings and have found that there is a very noticeable differencet between high, mid and low. I like high the best on all three of my tubes. The sound on mid seems to highlight the mids more and also expand the soundstage, unnaturally to my ears. But the difference between the output resistance settings is much larger than the difference between the tubes. The input gain doesn't seem to have any other effect except to increase or decrease the volume. I am using high gain as with low I'm usually in the 2-3 o'clock position, which for some reason I find abnormal as I'm used to integrated amps where I'm normally in the 9-11 o'clock.
