Pro-Ject Pre Box S2 Digital Impression Thread
Dec 6, 2017 at 6:58 AM Post #136 of 784
New S2 onwer here. I purchased this to replace the Audioquest Dragonfly Red in my work laptop. No complaints so far - this is a sturdy little quality box, that sounds great!
Dec 6, 2017 at 10:02 AM Post #137 of 784
What amp are you using with Pro-Ject? I am thinking about getting Magni 3 or Asgard 2 + Pro-Ject.
Running the Pro-Ject pre outs into my Magni 2U sounds better to me. If you also also use a speaker amp or powered speakers you'd need RCA Y cables. My speaker amp is an SMSL A2 TDA7492.
Dec 6, 2017 at 10:07 AM Post #138 of 784
It has arrived in the USA:
http://www.audioadvisor.com/prodinfo.asp?number=PRPRBS2D
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias=aps&field-keywords=pro-ject+pre+box+s2+digital
The Pro-Ject support manager told me last week they're still waiting for the final firmware update release, and will put it on their website when they have it. Meanwhile I'm still giving out the 2.11 beta via PM. It behaves like a final release, and solves the clock-change popping sound as well as the DSD channel reversal problem.
Dec 6, 2017 at 10:29 AM Post #139 of 784
I am not going to use it with speakers but with headphones (HD 650, HD 660 S, Fostex TH-X00, in near future probably HD 800 S). Did you compare Magni 2U with Magni 3/Asgard 2 that you are saying it sounds better with Magni 2U? Thanks.
Dec 6, 2017 at 11:17 AM Post #140 of 784
I've not heard the Magni 3 nor any Asgard, but Schiit has a characteristic sound. Some say the Magni 3 sounds warmer than the Magni 2U, some disagree. This has been discussed endlessly over on the Magni 3 Impressions thread.
To me the Magni 2U is warmer and richer than the Pre Box S2 Digital head amp, but it's not a large dfference, and some may prefer the S2 Digital's neutral sound as crisp and maybe somehow brighter.
All Magni models are far more powerful than the S2, and would be better able to drive your high-ohm cans. They're so much more powerful that at first they may just sound better than the S2 because they're louder, but I controlled for that. Hope this info helps.
Dec 6, 2017 at 11:46 AM Post #141 of 784
I want use Pre Box S2 just like DAC (instead of Modi for example) and Magni 3 use as an amp. I think that amp in S2 is not powerful enough (just 68mW into 32 Ohms VS impressive 2 watts into 32 Ohms - Magni 3)
Dec 6, 2017 at 11:59 AM Post #142 of 784
I want use Pre Box S2 just like DAC (instead of Modi for example) and Magni 3 use as an amp. I think that amp in S2 is not powerful enough (just 68mW into 32Ohms)
Sorry if my second paragraph wasn't clear: to do a fair comparison, I fed the Magni 2U with the Pre Box S2 Digital as the DAC, instead of my Modi 2U.
My third paragraph supports your belief that the Magni will be better able to drive your high-impedance headphones.
Dec 6, 2017 at 12:02 PM Post #143 of 784
Did you try to compare the Modi 2U with Pro-Ject? Is the Pro-Ject a lot better than Modi 2U?
Dec 6, 2017 at 12:25 PM Post #144 of 784
Here's an excerpt from my first impressions post:
Comparing only the DAC to my Modi 2U, with both outputting via their preamps to my Genelec M030 active desktop monitors, I find the two products so close in sound that I wonder if I am falling prey to expecation bias when I hear any difference at all, but I do find the Modi 2U to be just a bit smoother.
To get it the Pro-Ject to that level, use the external power adapter instead of USB power. And for both DACs I use an anti-jitter accessory on the USB inputs.
Dec 6, 2017 at 5:13 PM Post #148 of 784
Lake people RS 02 HPA. Ds2 could drive hd 650 quite well and sounded a little clearer but i think there was a little more punch in the bass with rs 02 amp.
Dec 7, 2017 at 9:00 AM Post #149 of 784
Soundwave76, can you give us some details about Dragonfly Red vs. S2? I currently use a DF Red with my laptop and I'm seriously thinking about getting the S2.
Dec 7, 2017 at 11:18 AM Post #150 of 784
The final firmware update, version 2.12, has been released. This update fixes the "popping" sound and the DSD right/left channel reversal, and MQA dropouts. There is also a new driver/control panel.
PM me for that update, the driver/control panel update, and my user manual corrections to the sections on power connections and on DSD/MQA local file playback setup. Some of this is on the Pro-Ject website, but I think you'll find my approach more helpful.
