pearljam5000
- Dec 23, 2006
does the k701 have enough bass with the pico?would it be a good combo for rock and metal?
Originally Posted by pearljam5000 /img/forum/go_quote.gif does the k701 have enough bass with the pico?would it be a good combo for rock and metal? |
Originally Posted by kugino /img/forum/go_quote.gif i don't know if the k701 is the headphone i'd immediately think of for rock and metal. i think the pico can provide the necessary oomph for rock and metal, but i'd probably go with a different headphone... |
Originally Posted by 3x331m /img/forum/go_quote.gif I'm not sure how you had the setup, but my Predator volume knob has never been passed 9 o'clock mark with HD650 or HD600, unless I'd want to pierce my eardrums. |
My workstation uses the ASUS P35 which is not very clean. I had noise problem with the Corda Move on this same workstation. However, I found the Predator sound is as clean as the Rudistor NKK-01SE. I don't benchmark DAC, but I found that the Predator noise floor is as good as the Rudistor NKK-01SE. Anyway, the Predator price is less than half the price of the NKK-01SE. Again, I don't compare DACs. I only compare the sound quality, because I only see systems. |
The Noise on the Corda Move is confirmed by Jan. It can be very bad on some PC/laptop, depending on the integrated mobo. I also have the Bithead. As the amp, the Bithead don't stand against the Move, Predator, or Pico, but I never had any noise issue with the Bithead no matter the source. |
Originally Posted by jamato8 /img/forum/go_quote.gif Yes, I have been around high end stereo long enough and have built enough systems and tube equipment to know that loudness does not denote quality so I should clarify that the Predator goes beyond what I can stand to hear in volume and still maintains control without distortion in the frequency range. I don't doubt that what heard but my experience with the amp is different. I guess that is part of what makes much of the discourse we see here interesting and informative. |
Originally Posted by Edwood /img/forum/go_quote.gif As I already stated Fujitsu P1610 + Foobar 2000 + FLAC. Some of my classical music songs are very quiet, particularly the reference DSD mastered stuff. Must have been recorded at a very low level. It is significantly quieter than other music I have. I compared the sound quality coming out the DAC's. But despite just the musical ability, in my portable system, the Predator's noise level was completely unacceptable. Again, it can be a crap shoot depending on your system. In this case, the Predator didn't do well with my Fujitsu. -Ed |
Originally Posted by 3x331m /img/forum/go_quote.gif No offense. I can ignore your statements. However, I think you could have made your statements a bit more neutral when you compare the 2 amps. There were quite a few assumptions when you try to put down an amp based entirely on the Fujitsu alone. I know Fujitsu PC/laptop products and would not make comments on their quality. |
Anyway, your statements made me think that you're a fanatic Pico fanboy, or an associate of Headamp. I'm sorry if my statements are extreme, but I won't crap this thread at personal level. |
Originally Posted by 3x331m /img/forum/go_quote.gif No offense. I can ignore your statements. However, I think you could have made your statements a bit more neutral when you compare the 2 amps. There were quite a few assumptions when you try to put down an amp based entirely on the Fujitsu alone. I know Fujitsu PC/laptop products and would not make comments on their quality. Anyway, your statements made me think that you're a fanatic Pico fanboy, or an associate of Headamp. I'm sorry if my statements are extreme, but I won't crap this thread at personal level. |
Originally Posted by jamato8 /img/forum/go_quote.gif I think some of the feelings expressed relate to the knowledge that it would be doubtful that either Ray or Justin would produce an amp that would deviate so far from what would be acceptable in the "audiophile" world or anywhere else. I don't think it would get out the door. If someone had said the Predator was great but when I listened to the Pico, there was so much hiss that acceptable sound reproduction is very questionable, I would not assume that everything was correct in the comparison. If I read that, even if I hadn't heard the Pico, I would really question whether something was not wrong with the pairing or the unit being used and having read comments by other people that never mentioned the hiss would even bring more into suspect the correct functioning of unit or pairing. |
