FallenAngel
Uhm... I think I see a few little problems.
First off, you're mixing MJE253 and BD139, I don't think that's a good idea, even those they are PNP / NPN accordingly, I don't think they work together well, they're opposites - one is much lower output current than the other, you're asking for trouble mixing them.
Reading 45mV across the output resistors, even with 2R2 resistors is only 20mA of current, which is pretty low and you're likely to want to raise it to decrease the chance of oscillation. Even using 2R2 isn't advised because it might be unstable, I upped mine to 4R7 to stabilize the buffer.
The AD843 is also a little cranky in the PPAv2 for some reason, I read Tangent had problems with this chip, especially in ground (as well as on Pimeta) not sure why, but I didn't chance it using this chip.
