I just received a PPAv2 + STEPS stack.
Here are the essential measurements:
Gain: ~9
Output buffer bias: ~45mV (measured across all buffer output resistors)
Opamp bias: ~1mV (measured across R10)
Output transistors: BD139 and JE253
STEPS is putting out 24v.
However I experienced some strange things.
Only when using my DT880s I got some wierd funky as distortion/white noise when I turned up the volume knob and it got to a loud part of the a song it would go out of control and then even if I turned down the knob the crazy noise stayed. Is this oscillation?
It happened in a couple of opamp combinations:
2 x OPA637 + 1 x OPA627
and
3 x AD843
It only happened with the above opamps and with the 250 ohm DT880, does anyone know what's happening?
Other headphones/opamps used without issue were K501, K701, DT531, 3 x AD8610, 3 x OPA627, 2 x AD744 (using comp pin hack) + AD829.
I've ruled out oscillation due to low gain, unless I'm reading/measuring the gain resistors wrong (possibly) here's a picture of the left channel gain resistors, right is identical:
I plugged the values of R3, R4, R5 and R6 into tangent's gain calculator
Electronics Calculators and got ~8.9 if anyone would like to confirm... (I can't figure out how to read resistors, I just measured across their leads with my multimetre)
What else might cause oscillation or whatever's happening?
