I thought I had resolved my 'ground' issues at my new location (my Aliendac failed chip gets REALLY hot, but no audio output). Ha no ground problem at all!
I got feed up with no PPA at work, so I brought it back in and plugged it into the built in sound on my MB.
I didn't have my STEPS with me so I used a 16V laptop power supply (sucky, but better than nothing, SOO MUCH BETTER).
The next day I brought the 24V Steps in and hooked it up. I got horrible white noise and muffled-weird-phased music.
When I touched the (grounded) case of the STEPS the white noise changed! I made sure the steps and ppa were not touching chassis or anything.
I'm happily back on the laptop power, but any ideas what is wrong? Could my work have a poor ground? The power DOES run through a cubicle tray system.
I checked the STEPS, I get continuity between chassis and AC ground pin, and no continuity between +- DC or either phase of AC.
** Update **
Update, after an hour of bliss I walked away and came back to some hiss (not like before though, the audio was not muffled or out-of-phase sounding). The hiss does not increase/decrease in volume in relation to input volume (pc volume) or analog volume on the amp. For kicks I pulled the gnd opamp and hiss went away. I swapped chips (no change), then I got crazy and shorted pins 3 to 5 of the gnd opamp together (+ in to output), NO HISS! I've since pulled the ground opamp out and shorted from pin 3 to pin 5 (R1G to R10G), the socket holds the wire well.
No parts were too hot to touch and opamps were cold as ice. Maybe I have some instability? Can that sound like constant hiss? Or maybe it is just an artifact of running the PPA without an (presumply) isolated power supply.
AD8610 in all 3 locations. Should I buy/try a different model GND opamp, or add some resistance/capacitance between pins 3/5?
4 years later, here is an update!
After 4 years of running off a 16v switch-mode power supply and bypassing the ground channel, I finally decided to fix my amp, darnit!
I recently got a smart load, so hooked my STEPS (at 24v) up and confirmed everything was good with a 120ma draw. I lowered voltage to 16v to match my SMPS at work and rule out the 24v causing the issue.
I confidently brought it into work, swapped out my SMPS with the STEPS and powered it on. Everything seemed normal until I touched the STEPS and PPA at the same time, massive white-noise! WHAAA?!
I took a page from 1950s style troubleshooting and thumped the STEPS a good one and BAM no more right channel!
Upon closer examination of the case, it appears my heatsink was making contact with the side when the lid was installed AND the back screwed on, but not when the screws were removed!
I've now insulated this area with a long piece of hot glued lego axle (don't judge, it fit perfect in the hammond case's rails).
The PPA suffered 3 dead 2n5486 power rail isolation jfets. 1 in the right channel and 2 in the ground. I'm assuming I blew the ground channel ones 4 years ago
I still had spares, so I swapped them out and will be bringing the amp back into work on monday, wish me luck!!
** UPDATE ** I'm at work, listening to Orbital's 'The Box' and it sounds so beautiful...I can't even **
