I thought I had resolved my 'ground' issues at my new location (my Aliendac failed chip gets REALLY hot, but no audio output). Ha no ground problem at all!
I got feed up with no PPA at work, so I brought it back in and plugged it into the built in sound on my MB.
I didn't have my STEPS with me so I used a 16V laptop power supply (sucky, but better than nothing, SOO MUCH BETTER).
The next day I brought the 24V Steps in and hooked it up. I got horrible white noise and muffled-weird-phased music.
When I touched the (grounded) case of the STEPS the white noise changed! I made sure the steps and ppa were not touching chassis or anything.
I'm happily back on the laptop power, but any ideas what is wrong? Could my work have a poor ground? The power DOES run through a cubicle tray system.
I checked the STEPS, I get continuity between chassis and AC ground pin, and no continuity between +- DC or either phase of AC.
** Update **
Update, after an hour of bliss I walked away and came back to some hiss (not like before though, the audio was not muffled or out-of-phase sounding). The hiss does not increase/decrease in volume in relation to input volume (pc volume) or analog volume on the amp. For kicks I pulled the gnd opamp and hiss went away. I swapped chips (no change), then I got crazy and shorted pins 3 to 5 of the gnd opamp together (+ in to output), NO HISS! I've since pulled the ground opamp out and shorted from pin 3 to pin 5 (R1G to R10G), the socket holds the wire well.
No parts were too hot to touch and opamps were cold as ice. Maybe I have some instability? Can that sound like constant hiss? Or maybe it is just an artifact of running the PPA without an (presumply) isolated power supply.
AD8610 in all 3 locations. Should I buy/try a different model GND opamp, or add some resistance/capacitance between pins 3/5?
