- Apr 28, 2010
Oh yeah, forgot to add, you can search for SilentPCReview's review of the FT02B which cover the noise levels, and check out 3DGameMan/Rodney 'I talk like a robot' Reynolds review on YouTube which also has a fan noise test. I think the noisiest components will probably end up being the HDDs or any coolers on the GPU, especially if it's something insane like a GTX480.
Here's the SilentPCReview noise testing for the case:
[size=1em]
SilverStone Fortress FT02B Baseline Noise Measuring mic positioned 1m at diagonal angle left/front of case | |||||
12cm fan | 18cm fan front | 18cm fan mid | 18cm fan back | SPL (dBA@1m) | |
FT02 | RV02 | ||||
9V-750rpm | low | low | low | 19 | 19 |
full speed | low | low | low | 21 | 20 |
any speed | high | low | low | 23~24 | 23 |
any speed | low | high | low | 23 | N/A |
any speed | low | low | high | 23 | 23 |
any speed | high | high | low | 27 | 26 |
any speed | low | high | high | 26~27 | 26 |
any speed | high | low | high | 27 | 26 |
any speed | high | high | high | 30 | 28~29 |
http://www.silentpcreview.com/article1015-page5.html
Hope this helps. The YouTube review is with the older fans. With the newer fans the 5970 fits without problem. Also you might notice the RV02 is quieter in that table, but when a full enthusiast system is installed the FT02's overall volume doesn't go up as much.
